iChr = UltraEdit.activeDocument.selection.split(",");
for (i=0;i<iChr.length;i++) {
if(iChr[i]=="00")
continue;
UltraEdit.activeDocument.write( String.fromCharCode(parseInt( iChr[i], 16 )) );
var iLines = UltraEdit.activeDocument.selection; /* get selection - even multi lines are ok */
var iLines = iLines.replace(/[\\ ]/g,""); /* remove spaces and continuation chars */
var iLineArr = iLines.split("\r\n"); /* explode lines into an array */
var chrCount = 0; /* we will ignore every 2nd hex (00) */
var oStr = ""; /* gather output in this */
for (i=0;i<iLineArr.length;i++) { /* run through lines */
iChr = iLineArr[i].split(","); /* explode single line into array */
for (j=0;j<iChr.length;j++) {
if(iChr[j].length==0) { /* just in case */
continue; /* = skip empty */
chrCount++; /* hex char counter */
if(chrCount % 2 == 0) { /* counter modulus 2 */
continue; /* = skip every 2nd char */
if(iChr[j]=="00") { /* break at field delimiter */
oStr = oStr + "\r\n"; /* DOS line terminators: CR LF */
continue;
oStr = oStr + String.fromCharCode(parseInt( iChr[j], 16 ));
/* write back the text */
UltraEdit.activeDocument.write(oStr);123greetings.com
Alem2358@aol.com
BellExpressVu@bell.ca
CNET_Networks_Member_Services@newsletters.online.com
DPJohnston@shaw.ca
var txt = "j";
UltraEdit.outputWindow.write(txt.charCodeAt(0).toString(16));
