Find in the selection
Postby mathmax » Mon Oct 15, 2007 11:24 am
Is there a way to make the Find instruction apply only on the selected text ? For example I would like to check if the selected text match a regular expression. How can I do that with a macro?
mathmax
Re: Find in the selection
Postby Mofi » Mon Oct 15, 2007 1:10 pm
This was so often asked and the answer was always the same: NO (for UE < 14.00).
I have written about a workaround by using Replace All SelectText "..." in macros which can be in some situations used as I have done it several times in my macros - see my sticky forum topic in the macro forum and the documentations in the ZIP archive you can download there.
A workaround is always to copy or cut the selection to a new file and run the finds there.
With the script engine it is now also possible to load a selection into a string variable and run a replace on this variable. I don't know if it is also possible to run a find only on a string variable. Never needed this and so never tried it.
Edit on 2009-10-09: With UltraEdit v14.00 and UEStudio v6.50 and later it is possible to search only in the current selection. But when a string is found in the selection, the selection is discarded and a new selection is made containing only the found string.
Postby jorrasdk » Mon Oct 15, 2007 2:26 pm
Just to answer Mofis question regarding scripts and finds on string variables:
You could for example do something like this: The script checks if a simple SQL date pattern can be found anywhere in a selection and shows a message box with the result:
var selectedText = UltraEdit.activeDocument.selection; /* get selected text */
if(selectedText.length>0) { /* anything selected ? */
   /* let's search for a simple SQL date patttern */
   var findResult = selectedText.match(/\d\d-\d\d-\d\d\d\d/); /* javascript use it's own Perl regexp engine */
   if(findResult==null) { /* nothing found returns a null object */
      UltraEdit.messageBox("Date pattern not found");
   else {
      UltraEdit.messageBox("Date pattern found: "+findResult);
To mathmax: The above will only work if you are using UE version 13 and above.
Postby mathmax » Mon Oct 15, 2007 8:46 pm
The problem is that scripts cannot be executed with shortcuts...
mathmax
Postby jorrasdk » Mon Oct 15, 2007 9:49 pm
Sure they can if you by shortcuts mean hotkeys. I use it all the time. Access Scripting - Scripts... menu and notice the Hotkey and chord columns. Just click in the hotkey column beside the script you want to assign a hotkey. Then press the key combination you want.
