Capitalize first letter of each line
Postby caveatrob » Wed Jun 04, 2008 4:49 pm
Hi All,
I frequently take notes without capitalizing the first letter of each line. I'd like to do that with an UltraEdit script. How would I do so?
Rob
caveatrob
Re: Capitalize first letter of each line
Postby mjcarman » Wed Jun 04, 2008 8:22 pm
You don't need a script. A search and replace will do it just as well (and faster).
Find What: ^(\s*\w)
Replace With: \U$1
Be sure to check Regular Expressions and select Perl as the regex engine.
Since it sounds like you'll want to use it regularly you can run it from a macro:
PerlReOn
Find RegExp "^(\s*\w)"
Replace All "\U$1"
mjcarman
Power User
Power User
Capitalizing the first letter of each line
Postby caveatrob » Tue Jun 10, 2008 9:38 am
Hi all,
I've got a script that I modifed from a Macro to capitalize the first letter of each line. It doesn't seem to do -- anything.
Any ideas?
    // Is any file currently open?
       UltraEdit.ueReOn();
       // Is the last line of the file terminated with a line ending?
       if (UltraEdit.activeDocument.isColNumGt(1)) {
          // No, insert missing line ending (DOS, UNIX or MAC).
          UltraEdit.columnModeOff();
          // If auto indent is enabled and last line starts with white-spaces,
          // delete the automatically inserted white-spaces in the new last line.
       UltraEdit.activeDocument.findReplace.replace("^(\s*\w)","\U$1");
caveatrob
Re: Capitalizing the first letter of each line
Postby jorrasdk » Tue Jun 10, 2008 10:00 am
Business as usual: Backslashes must be escaped in strings in javascript:
UltraEdit.activeDocument.findReplace.replace("^(\\s*\\w)","\\U$1");
and you are using Perl regexp, so add UltraEdit.perlReOn();
Postby caveatrob » Tue Jun 10, 2008 12:40 pm
That was it. Thank you very much! Has anyone given a thought to a wiki for UltraEdit scripts? I'd be happy to help putting it together.
caveatrob
