Keep/drop a random sample of rows from text (.csv) files?
Postby richardl » Mon Aug 17, 2009 9:36 pm
I'm not sure if this is the right place to ask the question, but I was wondering if there is a way to randomly keep or drop rows in a text file using Ultraedit? For instance, randomly drop 10% of the rows, or 1000 of the rows throughout the text file?
If anyone can give me some suggestions on how to do this, I'd really appreciate it.
Thanks! :)
richardl
Re: Keep/drop a random sample of rows from text (.csv) files?
Postby jorrasdk » Mon Oct 05, 2009 9:57 am
Hi! Needed a small challenge for a coffee break :-) - and maybe you have already solved this in a different way, since you wrote your request in August.
You will need a script for this and thus use a newer version of UE supporting scripts. And here is an example script which will delete x percent of rows (lines) in a csv file. See the variable g_nDropPercentage near the top. I hope you can understand the script from the embedded comments:
// Define percentage of rows to be dropped. Integer Number between 0 and 100.
var g_nDropPercentage = 10;
// Call as function:
dropRandomRows();
function dropRandomRows() {
  // is is a csv file - if not quit this function
  if(! UltraEdit.activeDocument.isExt("csv")) {
    return;
  // Go to bottom of active document
  // Ensure last line has line ending
  if (UltraEdit.activeDocument.isColNumGt(1)) {
    if (UltraEdit.activeDocument.isColNumGt(1)) UltraEdit.activeDocument.deleteToStartOfLine();
  // Line after the last line endning is not counted, hence minus 1
  var nTotalNumberOfLines = UltraEdit.activeDocument.currentLineNum - 1;
  // Drop further action on empty files
  if(nTotalNumberOfLines < 1) {
    return;
  // Calculate the number of lines to be dropped:
  var nNumberOfLinesToBeDropped = Math.floor( (nTotalNumberOfLines / 100) * g_nDropPercentage) + 1;
  // If to few lines - drop further action:
  if(nNumberOfLinesToBeDropped<1) {
    return;
  // while there are still lines to be dropped - iterate:
  while(nNumberOfLinesToBeDropped>0) {
    // calculate a random line number:
    var nRandomLineNum = Math.floor( Math.random() * nTotalNumberOfLines);
    // Goto random line and delete it:
    UltraEdit.activeDocument.gotoLine(nRandomLineNum,0);
    UltraEdit.activeDocument.deleteLine();
    // Decrease total number of lines by 1:
    nTotalNumberOfLines--;
    // Decrease number of lines to be dropped by 1:
    nNumberOfLinesToBeDropped--;
