Using RegEx on UTF-8 documents
Postby Khuri » Sun Nov 22, 2009 8:09 am
Hello!
I've recently tried to dig into UTF-8 format (thanks to this thread, was a great read) and everything seems to work fine, except using RegEx.
I'm using a script when saving documents that determines wheter it is a script document of mine, including a particular header string stating the time the file was created and edited last.
The script works fine on ASCII/ANSI documents, however this regex search fails on UTF-8 documents and i fail to see why.
The header part looks like this:
// File written by Jochen "Khuri" Höhmann <mailadress>
// Copyright 2009
// File        : test.php
// Begin       : 2009.11.22 13:45:32
// Last Update : 2009.11.22 13:47:54
This header (and some possible variations) is added using templates.
Now when i save a document, the following script is executed.
var cline = UltraEdit.activeDocument.currentLineNum;
var crow = UltraEdit.activeDocument.currentColumnNum;
if (typeof(UltraEdit.activeDocumentIdx) == "undefined") crow++;
UltraEdit.activeDocument.findReplace.mode = 0;
var is_privdoc = UltraEdit.activeDocument.findReplace.find("File written by Jochen \"Khuri\" Höhmann <mailadress>");
if(is_privdoc == true) {
   var time = new Date();
   var currdate = time.getFullYear()+'.'+(((time.getMonth() +1).toString().length > 1) ? (time.getMonth() +1) : '0'+(time.getMonth() +1))+'.'+((time.getDate().toString().length > 1) ? time.getDate() : '0'+time.getDate())+' '+((time.getHours().toString().length > 1) ? time.getHours() : '0'+time.getHours())+':'+((time.getMinutes().toString().length > 1) ? time.getMinutes() : '0'+time.getMinutes())+':'+((time.getSeconds().toString().length > 1) ? time.getSeconds() : '0'+time.getSeconds());
   UltraEdit.perlReOn();
   UltraEdit.activeDocument.findReplace.regExp = true;
   if(UltraEdit.activeDocument.findReplace.find("// Copyright "+time.getFullYear()) == false) {
      UltraEdit.activeDocument.findReplace.replace("\\/\\/ Copyright (?:\\d{4})","// Copyright "+time.getFullYear());
   if(UltraEdit.activeDocument.findReplace.replace("\\/\\/ Last Update : [\n\r]","// Last Update : "+currdate+"\n") == false) {
      UltraEdit.activeDocument.findReplace.replace("\\/\\/ Last Update : (?:\\d{4}\\.\\d{2}\\.\\d{2} \\d{2}:\\d{2}:\\d{2})","// Last Update : "+currdate);
UltraEdit.activeDocument.gotoLine(cline,crow);
UltraEdit.save();
Both lines
and
fail to work on UTF-8 documents.
I assume it might have to do with the way digits are handled in UTF files? Yet so far i fail to figure out what's wrong here...
Any help is greatly appreciated. Thanks in advance! :)
Khuri
Re: Using RegEx on UTF-8 documents
Postby pietzcker » Sun Nov 22, 2009 3:27 pm
I don't use the scripting engine of UE, so I'm not sure what's going on.
Two things to consider, though: First, no need to escape the forward slash. It has no special meaning in regex (if used in a JavaScript string instead of a JavaScript regex object where it does have a special meaning). I don't think that this is breaking your regex - but try that first.
Second, try [0-9] instead of \d and see if that changes things. If it does, then there might well be something wrong with the regex engine in UE's JavaScript implementation. Bego is the JavaScript expert around here, so I'm curious about what he thinks about this.
pietzcker
Postby Mofi » Mon Nov 23, 2009 2:37 am
Something strange is going on here which I must further analyze. It looks like the replace command finds the strings, but does not replace them correct for Unicode files. In the meantime you can use this script.
UltraEdit.activeDocument.findReplace.searchAscii=false;
   var curryear = currdate.substr(0,4);
   if(UltraEdit.activeDocument.findReplace.find("// Copyright "+curryear) == false) {
      UltraEdit.activeDocument.findReplace.find("// Copyright \\d{4}");
      UltraEdit.activeDocument.write("// Copyright "+curryear);
   if(UltraEdit.activeDocument.findReplace.replace("// Last Update : [\\n\\r]","// Last Update : "+currdate+"\n") == false) {
      UltraEdit.activeDocument.findReplace.find("// Last Update : \\d{4}\\.\\d{2}\\.\\d{2} \\d{2}:\\d{2}:\\d{2}");
      UltraEdit.activeDocument.write("// Last Update : "+currdate);
UltraEdit.save();
Edit: I reported the problem by email after deeper analyzing it and got already a reply that IDM support could reproduce the issue.
Postby Khuri » Wed Nov 25, 2009 1:54 pm
Whew, kinda glad it's a bug then and not me. Spend quite some time trying it out over and over again, but the normal UE replace function is not working either as you stated Mofi. Have to keep that in mind as I'm using regular expressions quite often. So let's hope IDM fixes this soon.
Anyhow, thanks for your script replacement Mofi, it works fine :)
Khuri
