I'd like a script that prompts me for a file mask and then closes all the files currently open in the editor that match that mask.
E.g. "*.txt" would close all the .txt files open in the editor.
Thanks!
var nFileCount = UltraEdit.document.length;
// Is at least 1 file open?
if (nFileCount > 0) {
// Let the user enter the file extension string.
var sExtension = UltraEdit.getString("Enter file extension",1);
// The user should enter just the file extension, for example
// just TXT. In case there is something left the file extension
// like "*." or just "." remove that part of the entered string.
var nPointIndex = sExtension.lastIndexOf('.');
if (nPointIndex >= 0) sExtension = sExtension.substr(++nPointIndex);
// Normally it makes sense to run the file close loop only when the
// remaining string is not empty now.
if (sExtension.length) {
// Convert the file extension to lower case.
sExtension = sExtension.toLowerCase();
// Run the file closing loop from last to first. Running it in reverse
// direction is important whenever a loop is executed on a dynamic
// list which removes items from the list. Because removing an item
// from the list results in moving everything with a higher index
// down in the list, removing items from first to last would need to
// permanently check the modified list count property and the index
// can be increased only when an item is not removed. Running the
// loop in reverse order from last to first avoids all that problems
// and the loop is executed much faster.
var nFileIndex = nFileCount;
do {
var sActFileExtension = GetFileExt(--nFileIndex);
if (sExtension == sActFileExtension.toLowerCase()) {
UltraEdit.closeFile(UltraEdit.document[nFileIndex].path,0);
while (nFileIndex);
}var nFileCount = UltraEdit.document.length;
do
if (UltraEdit.document[--nFileIndex].isExt(sExtension)) {
while (nFileIndex);
