var WorkingFile = UltraEdit.activeDocument;
function KeywordCaseChange(SearchString)
WorkingFile.top();
// Do initial search for string
UltraEdit.perlReOn();
WorkingFile.findReplace.regExp = true;
WorkingFile.findReplace.matchCase = false;
var CompletionFlag = 0;
while (CompletionFlag == 0)
WorkingFile.findReplace.find(SearchString);
// If the initial search fails, END and return false.
if (WorkingFile.isFound() == false)
CompletionFlag = 1;
return false;
else
WorkingFile.toUpper();
WorkingFile.top();
KeywordCaseChange("\\bkeyword1\\b|\\bkeyword2\\b|\\bkeyword3\\b");
UltraEdit.columnModeOff();
while (!UltraEdit.activeDocument.isEof()) {
UltraEdit.activeDocument.write(" ");
UltraEdit.activeDocument.key("BACKSPACE");
UltraEdit.activeDocument.key("CTRL+RIGHT ARROW");
function KeywordCaseChange(KeyWordList)
WorkingFile.top();
WorkingFile.findReplace.replaceAll = true;
// Assemble the search string we need to do the initial tagging.
var SearchString = "^(((?!--).)*?)(?<!@@@)\\b(" + KeyWordList + ")\\b";
// Tag all the correct keywords by inserting "@@@" in front of them.
WorkingFile.findReplace.replace(SearchString, "\\1@@@\\3");
CompletionFlag = 1;
WorkingFile.top();
// Set the search string for the next stage, where we convert them to uppercase.
SearchString = "(?<=@@@)\\w+\\b";
CompletionFlag = 0;
CompletionFlag = 1;
else
WorkingFile.top();
// Remove all the tagging.
WorkingFile.findReplace.replace("@@@", "");
KeywordCaseChange("keyword1|keyword2|keyword3");
It also takes the keyword list in only one place -
acinfo64 wrote:The Mofi method has the advantage that it uses all the words of the uew file and it skips the comment, but I cannot write the keywords any more in lower case and I don't want to write in upper case all the time.
