Line number font
Line number font
Postby mstormo » Thu Nov 11, 2010 11:51 am
I've been using UltraEdit on Windows for years, and just love it.
I've recently started to use UEX on Ubuntu 10.10, and have an issue with fonts. The document looks good with a small font (the way I like it). My fonts in Ubuntu Appearance is also small, so all menus, dialogs etc are fairly small.
However, in UEX, the line number font is fixed to some size and font type which I cannot seem to affect. So now I only see half of each line number. Is there a way I can change this font (size)? It's really annoying, and might force me to disable line number all together, although I like to have them..
Screen shot of large line numbers.
Thanks!
.marius
mstormo
Re: Line number font
Postby AmpersandUSA » Thu Mar 03, 2011 4:33 pm
I have the same issue with not being able to change the font size. I've also noticed that this post is four months old so perhaps Marius if you've found an answer or work around, you can let me know too.
Thanks in advance - bob
AmpersandUSA
