Completion (CTRL-Space) does not work correctly
Postby spach » Mon Apr 18, 2005 6:53 am
I am using UEdit 11.00a+ and the completion (CTRL-Space) does not work accoding to the help pages.
The only completion with CTRL-Space which I get are language keywords, but not words contained above the current line, nor functions names as explained in the help.
I can remember that als that stuff did work some time ago, but I do not known what I have changed in the settings in the meantime. Actually there is no further configuration, I am right?
Does anybody have suggestions?
spach
Re: Completion (CTRL-Space) does not work correctly
Postby MrBillG » Mon Apr 18, 2005 9:51 am
Hi Spach
I'm not going to answer your question.
I'm going to suggest upgrading to version 11.10, which will show up as 11.10+1
Version 11. has been... a interesting release.
Here is the history of things fixed and enhancements.
v11.10   - New Icons
         - Clipboard conversion on paste, UNIX/MAC/DOS line endings
         - Enhanced "Save As" dialog
         - Replace in project files
         - Check for Updates capability
         - Auto-detect Unicode(UTF-16) files without BOM
v11.00b  - Fix for Toolbar configuration save and load from INI file
         - Fixed cursor positioning when toggling into HEX mode
         - Added new INI option for windows font: Extra Windows Font=Font Name (Default: Extra Windows Font=Tahoma)
         - Added new INI option for windows font size: Extra Windows Font Height=Font Size (Default: Extra Windows Font Height=13)
         - Added new INI option for file tab font: TAB Windows Font=Font Name (Default: TAB Windows Font=Tahoma)
         - Added new INI option for file tab font size: TAB Windows Font Height=Font Size (Default: TAB Windows Font Height=13)
         - Added "Use Check Marks on Menus" conguration for blind users
         - Fix for crash in Find in Files
         - Fix for crash while attempting to add invalid words to spell checker word list
         - Fix for Find in Files when searching Open Files and files are UTF-8/UTF-16
         - Fix for replace in files for open files when files are UTF-8/UTF-16
         - Fix for replace in all open files when files are UTF-8/UTF-16
         - Project settings dialog now shows complete path
         - Quick search toolbar entry now works if on multiple toolbars at once
         - Auto-complete fixes
         - FTP/SFTP bug fixes, including crash, and correctly reloading remote file
         - Fixes for automatic outdenting in Perl
         - Win 9x startup issue with ueres.dll
         - Crash with split windows and delete
         - Many changes for multi-language files with syntax highlighting, folding and indenting
         - File tree view sort now includes path
         - Project file fixes
         - Added capability to change size (length) of that search window in toolbar by double-clicking on the find combobox item in toolbar customization window
         - Fixed line number being chopped with some fonts
         - Many other minor issues
As you can see " Auto-complete fixes" was fixed in 11.00b.
Good Luck
MrBillG
Postby spach » Fri Apr 22, 2005 2:44 am
Thanks a lot, I upgraded to 11.10+1 and the auto-completion works again.
spach
