Use Menu Configurations and Environments
Postby amerifax » Thu Aug 02, 2012 9:59 pm
I want custom Menubars. RightClick\Manage Menu Configurations and I see a look of names. Programmer, Advanced & Permit (My Own) appear on the top of menu before going into Manage Menu Configurations. Selecting one of these3 does nothing different, Menus.
1. Only 3 names appear for a choice.
2. How do I get the rest as a selection, NotePad Replacement, Power User etc.
3. If Permit appears on the upper part of menu and selected,arrow, If I add to menu it should change right?
4. When in document & RightClick, content menu, I want to get ride of many items on this menu.
a. Can I save menu before deleting (So i can return to default)
b. What is this menu called. I need to find to change, if allowed to change.
I'm using the most resent UltraEdit Suite, which I will purchase on Friday. That is if I can figure this thing out. that's no true! I will be buying on Friday!
Whats first Chicken or Egg? I'm very serious. It seems there is a way to customize the menu with no clear way to select the menu. Try and find it in the HelpMenu. Not flaming, just confused!
Bob
amerifax
Re: Use Menu Configurations and Environments
Postby Mofi » Fri Aug 03, 2012 12:24 am
Before you start customizing any menus or toolbars and therefore change the environment, you should save the current environment with a customized name. Open View - Environments and use button Save Current State As. After doing that you should click on button Reset Built-In Environments to restore them if you have already made modifications. Select your environment and close the dialog with button Select Environment.
Note: On first start after an upgrade UltraEdit often asks the user for updating the menus and/or toolbars. You can accept those updates as the update is done only on built-in environments and never on custom environments. New features/commands must be added to a custom environment always manually by the user.
Now right click on the menu and left click in context menu on Customize Menu to customize the main menu. Right click on a toolbar and left click in context menu on Customize Toolbar to modify the toolbar of the active custom environment.
The context menu opened on right clicking into a document window has at bottom the command Customize Menu. After right clicking on tab of a file, there is again Customize Menu at bottom of the file tabs context menu to customize also this menu. These are the only 2 context menus which can be customized. All other context menus are built-in in resources of UltraEdit and can't be customized.
The customization dialogs for the toolbar and the 3 menus (main menu, file tabs context menu, document context menu) can be opened also in Advanced - Configuration - Toolbars / Menus - Customization.
Postby amerifax » Fri Aug 03, 2012 2:39 pm
Your response was better than I could expect. I'm up and running and loving it,
Thanks again
Bob
amerifax
