Current Line -> Top of View?
Postby bookman » Mon Mar 20, 2006 7:07 pm
Is there any way to easily scroll the currently selected line to the top line in the viewing area (i.e. one click or right mouse menu...)
bookman
Re: Current Line -> Top of View?
Postby Mofi » Tue Mar 21, 2006 7:24 am
Yes, you can move the current line (where the cursor blinks) with one key hit to top of view. Open Configuration - Key Mapping and scroll down in the list of commands to nearly the end of the list. There you will find some very useful functions which are not present in a menu:
CursorToEndofPreviousWord
CursorToEndofNextWord
CursorToNextParagraph
CursorToPreviousParagraph
CursorToTopOfWindow
CursorToBottomOfWindow
MoveLineToTopofView
MoveLineToCenterofView
MoveLineToBottomofView
Assign a hot key to the functions you often need and use it.
Postby bookman » Tue Mar 21, 2006 10:15 pm
Thanks! That's what I wanted. And it's already got a hotkey (Alt-Subtract).
I can safely say I never would have found that.
bookman
