How to add "Read only" button to toolbar in 12.10a?
Postby trelony » Fri Aug 04, 2006 5:31 pm
I used to put edit->read only button onto toolbar because I need it very ofter (plus I could see if the file has not been checked out). Recently we upgraded to UltraEdit 12 and new toolbar configuration provides only a very limited set of available buttons. Is there a way to add other buttons from menu bar (exit is also my favorite) onto toolbar?
- Alexey.
trelony
Re: How to add "Read only" button to toolbar in 12.10a?
Postby Mofi » Sat Aug 05, 2006 12:21 pm
Look at Missing ToolBar Command where I have described how to get a command in menu also to a toolbar.
ID_READONLY is the one you need in your *.tfg file.
Maybe see also Artistic Format which describes how to get a toolbar command to the menu.
Postby trelony » Sat Aug 05, 2006 5:47 pm
Thank you. For some reason the file was in windows folder (maybe because it was an upgrade). I had to search with UltraEdit itself without search string. However UltraEdit found the files, but double click on them did not work - I guess it requires to click on found context inside the file to open it.
trelony
Postby Mofi » Sun Aug 06, 2006 6:49 am
trelony wrote:For some reason the file was in windows folder.
Default location of UltraEdit prior v10.20d which is not changed during an upgrade.
trelony wrote:However UltraEdit found the files, but double click on them did not work - I guess it requires to click on found context inside the file to open it.
Correct. You have to click on the line with file name(line number): content...
