Cursor position affected
Postby protobion » Fri Oct 13, 2006 12:22 am
When I use UltraEdit on my Windows XP SP2, and I try to select text, the selection/highlighting always begins about 4 characters left of where my mouse cursor is positioned. I suspect this is a 'feature' that can be turned off. Can anyone tell me how to fix this?
protobion
Re: Cursor position affected
Postby jdhurst » Fri Oct 13, 2006 1:35 am
I checked that on my SP2 system and do not see that issue. I have almost vanilla configuration settings in UE.
jdhurst
Postby Mofi » Fri Oct 13, 2006 5:21 am
That effect is caused by a bad font (non-proportional font). First play with the ClearType and Font Quality settings at Configuration - Editor Display - Advanced. If that settings don't help, you must use a different font - see View menu.
