Multi-level code folding is built-in and should work independent of column. It works for me in 'C' and ASM files. Example:
- Code: Select all
@IF( @DEFINED (@DEFINE1) )
; ASM code
; ASM code
@ELSE
; ASM code
; ASM code
@IF( ! @DEFINED (@DEFINE2) )
; ASM code
@ENDI
@IF( @DEFINED (@DEFINE3) )
; ASM code
@ELSE
; ASM code
@ENDI
; ASM code
@ENDI ; End of ELSE branch of DEFINE1
Clicking on the MINUS at line of first @ELSE folds everything till last @ENDI.
Which version of UltraEdit or UEStudio do you use? Can you post an example where multi-level code folding fails and all the lines of the appropriate syntax highlighting definition in the wordfile from /Lx"..." till /C1"..."?
Second you can enable to save code folding on file close, so the file is opened next time with the same folding state as on last usage (enabled with config option
Save Bookmarks for UE < v12.20 or
Save folded lines for UE >= v12.20).
If the file was never opened before you can use
View - Hide/Show Lines - Collapse All with a self-defined hot key or you use a macro which is executed on every file load which folds the file based on file extension with the help of macro command
HideOrShowLines.
I have posted several macros with this command for a "customized collapse all on file load". Use forum search with the macro command name as search string and the select the search option
Search for all terms which is important for this (and most other) search(es).
