Add "Show / Hide Spaces and Tabs" in toolbar
Postby gn0rt0n » Tue Jul 31, 2007 7:51 pm
I cannot find the option to Show / Hide Spaces and Tabs to my toolbar. Can someone please tell me if I am just overlooking it, or if it is not available as a toolbar action?
gn0rt0n
Re: Add "Show / Hide Spaces and Tabs" in toolbar
Postby fgeurts » Tue Jul 31, 2007 10:39 pm
Click with right mouse button on your toolbar and then with left mouse button on Customize Toolbar item. Then scroll down the commands box on the right until you find the "Show spaces and tabs" entry. You can then add this to your tool bar. See attached screenshot.
Cheers...
Frank
Extra note by Mofi: You must have UltraEdit v13.10+1 or later. Please update if you use v13.10. (I also replaced the JPG screenshot with a PNG screenshot because much smaller file size and much better quality because of lossless compression.)
Screenshot of toolbar configuration dialog with "Show spaces and tabs" selected in the right pane.
fgeurts
