@echo off
set FileName=%1
if not exist %FileName% goto !EndBatch
rem Remove double quotes at begin and end of filename if present.
set FileName=%FileName:"=%
rem Get file name only without path and extension and get file extension only (with point).
for /f "usebackq delims==" %%i in (`echo "%FileName%"`) do (
set NameOnly=%%~ni
set Extension=%%~xi
copy "%FileName%" "C:\Temp\%NameOnly%_view%Extension%"
"C:\Program Files (x86)\IDM Computer Solutions\UltraEdit\Uedit32.exe" "C:\Temp\%NameOnly%_view%Extension%"
:!EndBatch
msvitale wrote:Can you tell me what release Uedit started working this way?
