For the first time I enable the UE Spell Checker option. I choose "Enable spell as you type", and since I am using "Syntax Highlightning" I enter the option EnableSpellasYouType like this :
/L15"Text files" EnableSpellasYouType Nocase Block Comment On = ( Block Comment Off = ) String Chars = " File Extensions = TXT
My problem now is that words with mixed case are still marked by the spell checker. "ResultsViewer" is underlined with red dotted line. Same with "words in all caps" and "words with numbers".
I restarted the application after turning on spell checker, and after editing the highlighting file, but it still does not work as expected.
I presume I am doing something wrong, but cannot see what.
Would be glad for a hint to push me in the right direction.
Using UltraEdit 15.20.0.1022.
Kind regards
Jørn Hanssen
