UltraFinder in Windows Explorer context menu?
Postby ddwashbu » Sat Mar 23, 2013 1:14 pm
I have been using SuperFinder XT as a Windows file search replacement for some years now. Unfortunately it is no longer being actively developed. Since I have also been using IDM products for years and love them, I decided to give UltraFinder a try. One of the things I appreciate about SuperFinder is that it adds a Windows Explorer context menu when it is installed. All I have to do is right-click and SuperFinder opens, ready to search that folder. So one of the first things I noticed about UF is that it doesn't set up a context menu item when it is installed. I looked around for a configuration option that might add a context menu item, but didn't see anything (JAM Software's UltraSearch uses this approach).
Short of adding a context menu item by hand, is there a built-in way to do it in UF? If not, I'd suggest this would be a great feature to add in the next version of UF!
Best regards,
Don
ddwashbu
Return to UltraFinder General Discussion
