UE 17.10.0.1015 error Find in Files (fixed)
Postby paul_ray » Tue Aug 02, 2011 5:42 pm
UltraEdit 17.10.0.1015
Windows XP SP3
I was using UE 17.10.0.1010.
I updated to 17.10.0.1015 on Monday, 2011/08/01.
Today I did a find in files using the "open files" and I get an error message "Search directory not found:" with the list of last selected directory path listed.
Note: The first time I received the error message, I had selected "Search in: Open Files" not "Files Listed".
I also get the same error if I do select "Files listed" if there is more than one directory listed.
I have narrowed the issue down to this version seems to have an issue with more than one directory in the search path. If I have just one directory it works.
Prior to this version, doing a fine in files worked okay.
There seems to be two issues:
1. The "Open Files" and "Project Files" are not ignoring the directories in the "files listed".
2. The "Files Listed" can not handle more than one directory.
The directories are being separated by a semicolon:
This worked in all versions of UE prior to 17.10.0.1015.
f:\root\data\;f:\root\reports\;g:\;d:\work\data\
I submitted an issue with support.
Has anyone else had this issue with 17.10.0.1015?
paul_ray
Re: UE 17.10.0.1015 error Find in Files (fixed)
Postby Mofi » Wed Aug 03, 2011 5:12 am
I can confirm all issues you reported in UE v17.10.0.1015 while all Find in Files are working fine in v17.10.0.1010 as you wrote too.
Postby paul_ray » Wed Aug 03, 2011 8:05 am
IDM wrote:This is known issue that our developers are aware of and working to resolve. We hope to have this fixed in a future release soon.
In the meantime, I am going to reinstall 17.10.0.1010.
paul_ray
Postby Mofi » Fri Sep 02, 2011 1:02 am
All issues reported here are fixed in UltraEdit v17.20.
Postby paul_ray » Fri Sep 02, 2011 9:41 am
I have tried 17.20.0.1013 and the issue with find in files now works as prior versions.
I also like the active column feature of this version.
paul_ray
