Finally learning REGEX, but need help
Postby lm77054 » Thu Dec 27, 2012 10:57 am
Hey all:
Yesterday I started to get into REGEX, because I started a project that is forcing me to. I read and played with REGEX all last evening, and I'm still having difficulty with the main items I need to use REGEX with. While in ULTRAEDIT, I tried the three main REGEX expressions I need, and I can't get them right. Let's say that you have the phrase:
The quick brown fox jumps over the lazy dogs back.
Here is what I'm trying to do:
1. If the item I'm comparing has "The " (the space is significant) at the beginning, remove it. But I don't want the second "the" messed with.
2. If the item I'm comparing has "back." at the end, remove it.
3. If the item I'm comparing has "over" in it, change it to "under".
4. Finally, if the item I'm comparing has "lazy", remove it completely.
I'm still trying to learn REGEX. After what "Mofi" helped me with before (thanks again, "Mofi"), it peeked my interest in it, but I was never forced into learning it; until now. I've gone through this forum, and I couldn't locate things similiar to this; hopefully someone can help.
For any help that can be given I will say THANK YOU, THANK YOU in advance!
I forgot to say, that I would be using a script that would be reading one line at a time and doing the comparisons, and only of for instance condition #1 applied, then make the change.
lm77054
Re: Finally learning REGEX, but need help
Postby spaceBAR » Thu Dec 27, 2012 3:13 pm
I like to use the "Perl" regular expressions engine, These are just examples of one way to do what you want to do:
In the "Find what" window put "^The " without the quotes and make sure the "Replace with" window contains nothing and click 'Replace All'.
In the "Find what" window put "back\.$" without the quotes and make sure the "Replace with" window contains nothing and click 'Replace All'.
In the "Find what" window put "over" without the quotes and put "under" without the quotes in the "Replace with" window and click 'Replace All'.
In the "Find what" window put "lazy" without the quotes and make sure the "Replace with" window contains nothing and click 'Replace All'.
Just a few Perl Regular Expressions Tutorials:
http://www.enginsite.com/Library-Perl-Regular-Expressions-Tutorial.htm
http://perldoc.perl.org/perlretut.html
http://www.comp.leeds.ac.uk/Perl/matching.html
Online Perl regular expressions testers:
http://retester-daoswald.dotcloud.com/
http://www.perlfect.com/articles/regextutor.shtml
spaceBAR
Postby Mofi » Fri Dec 28, 2012 5:01 am
What spacebar wrote is correct for what you wrote in your 4 points. But it looks like you want to run the replaces from within a script and with item in point 4 you mean an entire line.
   // Define environment for script.
   UltraEdit.columnModeOff();
   // Make sure that file ends with a line termination.
   if (UltraEdit.activeDocument.isColNumGt(1)) {
   // Define all parameters for the Perl regular expression replaces.
   UltraEdit.perlReOn();
   if (typeof(UltraEdit.activeDocument.findReplace.searchInColumn) == "boolean") {
   UltraEdit.activeDocument.findReplace.replace("^The ", "");
   UltraEdit.activeDocument.findReplace.replace("back\\.$", "");
   UltraEdit.activeDocument.findReplace.replace("^.*lazy.*\\r\\n", "");
   UltraEdit.activeDocument.findReplace.replace("over", "under");
Please note that in Javascript strings the backslash character is the escape character. So to pass a backslash character to the Perl regular expression engine of UltraEdit you have to escape every backslash in a search or replace string with one more backslash character.
