How do you change file extensions for all files in a directory?
Postby CrgEugene » Sun Jan 06, 2013 5:06 am
Hi. How do you change file extensions for all files in a directory?
For Directory D:\_Data\*.doc I want to change all the files to Directory D:\_Data\*.rtf.
Thanks for your help.
Craig
CrgEugene
Re: How do you change file extensions for all files in a directory?
Postby Mofi » Sun Jan 06, 2013 11:09 am
Why do you ask that in the forum of a text editor?
It is quite simple to rename all *.doc files in a directory to *.rtf. Just run in a command line window or via Run in Windows start menu the DOS command
ren D:\_Data\*.doc *.rtf
That's it.
