Adding numbers to text
Postby Alv_ » Thu Jun 02, 2005 1:43 pm
I have text like:
wildkat77   34229   persolta
west216   124392   persolta
warmknights   236506   persolta
Volleyball   22292   persolta
vincentkram   213993   persolta
vigoman22   73809   persolta
varsitystud   209343   persolta
to be replaced with
wildkat77   34229   persolta1
west216   124392   persolta2
warmknights   236506   persolta3
Volleyball   22292   persolta4
vincentkram   213993   persolta5
vigoman22   73809   persolta6
varsitystud   209343   persolta7
so that each line is unique
Also, how do I assign a random string to replace the "persolta" text?
Alv_
Re: Adding numbers to text
Postby JohnDoe » Wed Sep 13, 2006 10:43 am
Would interest me too!
JohnDoe
Postby Bego » Wed Sep 13, 2006 11:05 am
if you look here you will find a solution.
Mofi wrote a "countUp" Makro. The rest should be easy:
viewtopic.php?t=2821
rds Bego
Bego
Postby Mofi » Wed Sep 13, 2006 11:44 am
If you line up your lines better so "persolta" starts always at the same column you can also switch to Colmn - Column Mode and use Column - Insert Number to add a number at every line.
What do you mean with "random string"?
UltraEdit has no random generator to create really random strings.
