RegExp in Macro failing
Postby alanb » Thu Sep 15, 2005 11:50 am
I have a text file with up to 100000 lines like the following:
$P:U
$A:A
$C:Code_Opportunity
$U:N
$V:' '
$P:U
$A:A
$C:Code_Ratings_Code
$U:N
$V:' '
$T:CHAR(1)
Each "tag" starts with "$" and ends with ":". They should be in groups of 6 lines, one each of: $P: $A: $C: $U: $V: $T: in a group.
However, there may be some "$T:" tags missing (see the first group, above), so I want to parse the file and identify the missing "$T:" tags and insert them as "$T:<missing>".
To make matters worse, I will also have to do the same for missing "$V:" tags...
I tried the (Ultraedit style) Find RegExp "^$V:*^P%^$P:" but this finds every $V: tag. Also "^$V:*^P%^$P:" finds none.
Hope the above is clear, but what am I doing wrong?
TIA
alanb
Re: RegExp in Macro failing
Postby Mofi » Thu Sep 15, 2005 12:17 pm
Use ^$V:*^p^$P:
% (= start of line) can be only used once in the search string at begin of the search string. By specifying ^p you have already specified also start of next line. To see this, simply search for a single ^p and look where the cursor is now. It is not at the end of the line, it is at start of the next line.
Postby alanb » Thu Sep 15, 2005 12:21 pm
Thanks, Mofi - but this still does not work (copied and pasted from your reply)!
It finds:
$V:' '
$T:CHAR(1)
$P:U
and I need to find:
$V:' '
$P:U
$A:A
alanb
Postby Mofi » Fri Sep 16, 2005 5:37 am
You have found a bug within UltraEdit's regular expression. UltraEdit is selecting everything after second ^$ until a P: is found. If using ^$V:*^p^$*T: it finds
$V:' '
$P:U
$A:A
$U:N
$V:' '
$T:
and this is definitively not OK.
I found a workaround for this bug - use ^$V:*^p^$*P:
Postby alanb » Fri Sep 16, 2005 6:32 am
Thanks again Mofi - I guessed it had to be a bug & I'm mailing Ian and the Uedit team about it now.
Your workaround works fine!
But can you explain (why you think) it works, please?
Regards
Alan
alanb
Postby Mofi » Fri Sep 16, 2005 7:19 am
I have already sent an email about this problem to IDM support with a link to this forum topic and extra description.
I inserted the * after second ^$ because * means any numbers of characters which includes also number 0. I also don't know, why UltraEdit searches for P: after second $ and ignoring all characters between the $ and P:. We have to wait for the answer of the IDM developers.
Postby alanb » Fri Sep 16, 2005 7:58 am
OK Mofi.
The good news is that I am now able to replace 4 loops in my original macro with 4 RegEX Find/Replace which works many times faster.
I have another query with the macro which I'll post in the appropriate forum if I can't find an answer in previous posts.
Thanks again for your time,
Alan
alanb
