search within selected text
Postby jeoin » Fri Sep 01, 2006 5:48 pm
I need a method to search within the text I have selected. More specifically within columns.
Example I need to search for XY in the following text
01234 [position]
ASSDF
WERFS
XYEXY
AERED
DVPXY
I put the editor into column mode and select the last two columns. I would like to find both instances of XY in position 3 and 4, but not XY in position 0 and 1.
jeoin
Re: search within selected text
Postby Mofi » Sat Sep 02, 2006 11:32 am
A search cannot be limited to a specifc range, whether in normal nor in column mode. Use a regular expression search. For example in UltraEdit style - see search configuration settings:
Find: %???XY
Well, it marks also the first 3 characters. But this should be no problem. A small macro could be used to mark only the 2 characters if this is really important:
Find RegExp "%???XY"
Key LEFT ARROW
Key RIGHT ARROW
Key LEFT ARROW
Key LEFT ARROW
Macro property Continue if a Find with Replace not found is not important for this macro, but better uncheck it.
Postby MichaelF » Tue Sep 12, 2006 4:02 pm
I'm going to request it as a feature, but here's how I do it now:
Select the columns.
Use Replace.
Select "Selected Text" in the "Replace Where:" frame.
Put what you want to find in the "Find What:" box.
Tell it to Start, and just keep hitting Find Next.
This has its drawbacks, such as today, when I was looking through a file of 355,000 lines with lots of occurances of what I needed to find (I really like the "List Lines Containing String" feature in the real Find command).
I hope this takes care of your problem.
MichaelF
Postby dyslexic_dba » Wed Oct 11, 2006 11:11 pm
MichaelF wrote:I'm going to request it as a feature, <SNIP>
This would be a really useful thing for us.
We use UE for working on PL/SQL packages which contain many individual functions/procedures etc. It would be great if you could easily search just one procedure for something.
As it is now I just copy/paste the proc into another window to contain my search.
dyslexic_dba
