How to delete every second line?
Postby YanHan » Mon Nov 27, 2006 3:39 am
Does anyone have any ideas how to do this automatically?
YanHan
Re: Delete every second line?
Postby Mofi » Mon Nov 27, 2006 3:39 pm
A "simple" regular expression replace can do it:
In UltraEdit style:
Find What: %^(*^p^)*^p
Replace With: ^1
In Unix/Perl style:
Find What: ^(.*\p).*\p
Replace With: \1
Because of ^p or \p this works only for files with DOS line terminations (CR+LF). See in help of UE/UES the pages Find command or Replace command and Regular Expressions to understand it.
Postby YanHan » Tue Nov 28, 2006 4:56 am
Thanks, works perfecty, expect that the last line doesn't remove but it's easy to remove. :)
How about:
- Remove every last/first line?
- Remove every third line?
- Duplicate every line?
YanHan
Re: How to delete every second line?
Postby Bego » Tue Nov 28, 2006 10:22 am
The last line should always have a crlf to work properly.
1.: Use "TOP", "BOTTOM" and "DELETELINE" in an UE macro to do this job.
2.: Also a UE macro with key arrow down + deleteline + "EOF loop". Easy.
3.: Also a trivial UE macro with arrow down and duplicateline.
Bego
Bego
Postby YanHan » Tue Nov 28, 2006 3:35 pm
Thanks, Bego. But I don't get non of your advices working. :?
Is it possible to do these with the 'regular expression' feature?
YanHan
Postby Bego » Wed Nov 29, 2006 8:43 am
No. regexps are good for "inLINE-searching/replacing", not for navigating in a file.
Try this:
Create a macro called "delTopBottom"
Paste in those lines:
DeleteLine
Bottom
DeleteLine
Let it run on your example file. It should do your issue no. 1
rds Bego
Bego
Postby YanHan » Wed Nov 29, 2006 2:10 pm
Thanks once again, Bego. But it's not even works now. :?
I figured out these which can do only at the top of the document also 'Play macro to End of File' have to use:
1. Remove every last/first line
Key DOWN ARROW
DeleteLine
2. Remove every third line
Key DOWN ARROW
Key DOWN ARROW
DeleteLine
3. Duplicate every line (does not works - does not duplicate first line and the macro loops infinitely :?)
Key DOWN ARROW
DupeLine
YanHan
How to delete every second line in a text file?
Postby Doug E » Fri Dec 05, 2008 11:28 am
It's a small macro that is supposed to delete every second line in a file but stalls in the beginning.
Loop 0
MoveLineDown
MoveLineDown
DeleteLine
What have I missed?
Doug E
Re: How to delete every second line in a text file?
Postby Mofi » Fri Dec 05, 2008 1:00 pm
The command MoveLineDown does not only move the cursor down, it moves the entire line down. And you exit your endless loop after deleting 1 line because ExitLoop is inside the loop without any condition.
You don't really need a macro for that job because a single regular expression replace can do that too. However, here is the macro.
Bottom
IfColNumGt 1
IfColNumGt 1
DeleteToStartofLine
Find RegExp "%^(*^r++^n^)*^r++^n"
Replace All "^1"
This macro should work for files with DOS or UNIX line terminations, but definitely not for MAC files.
Postby Doug E » Fri Dec 05, 2008 4:48 pm
Ohh man, I can't believe how complicated a macro that turned out to be 8O
Thanks Mofi!
Keywords for others: remove delete every 2nd other line macro script
Doug E
