Inverse searching Regular Expression problem
Postby ktfung » Wed Aug 08, 2007 9:57 am
I have a problem in Regular Expression.
File 1 is:
ABCgg003D
if I want to search with any text start with BC and the end is 003 in File 1. I use BC*003 in find function. That work fine. Found 1 result.
File 2 is:
ABCgg002D
if i want text start with BC but not end with 003 in File 2. I have try BC*~^{003^}. I suppose 1 will be found. But the result is 0.
What Regular Expression should i use?
THX:)
ktfung
Re: Inverse searching Regular Expression problem
Postby Mofi » Wed Aug 08, 2007 11:04 am
First read the sticky forum topic in this forum. Then tell us your version of UE/UES and which regex engine you use.
Usually it is not possible to search "if a string is not at ...". With the UltraEdit and the Unix engine it is definitely not possible what you want. Only possible is "next character is not a or b or c or ..." by using [~abc] in UltraEdit syntax or [^abc] in Unix syntax.
If BC*~^{003^} should be an UltraEdit regex search string, than this is a completely invalid one and so does never find something.
Postby pietzcker » Wed Aug 08, 2007 12:04 pm
If you have an UE version >12, you can use the Perl regex engine that features negative lookahead.
BC(?:(?!003).)*$
will find "BC" followed by anything except 003 until the end of line.
I.e., ABCgg003D won't match, ABCgg002d will match BCgg002d.
HTH,
Tim
pietzcker
Postby ktfung » Thu Aug 09, 2007 1:55 am
Thanks for replies!
My UltraEdit version is 13.10a+1.
I have tried
BC(?:(?!003).)*$
, but the result still is 0 in File 2 (BCgg002d). Should I configure something before use Perl regex engine?
ktfung
Postby pietzcker » Thu Aug 09, 2007 5:44 am
Did you read the sticky, esp. section 2?
And of course, did you check "Regular Expressions" in the Find dialog?
pietzcker
