How to remove let's say 2 last characters in each line
Postby marino » Fri Dec 31, 2004 10:02 am
1. Is it possible to remove some characters on end of each line
2. The same question but for replace
marino
Re: How to remove let's say 2 last characters in each line
Postby mrainey56 » Fri Dec 31, 2004 1:06 pm
Unix Regular Expression Mode Active Advanced > Configuration > Find
Search String: ^(.+)..$
Remove last two:
Replace String: \1
Replace last two (with ZZ, for example):
Replace String: \1ZZ
mrainey56
Postby marino » Mon Jan 03, 2005 5:44 am
I found out that for ex. to delete 2 last characters this can be used:
..$ and replace with nothing.
One more question:
If on end of line I have numbers with different length for ex. from 1 to 4 numbers how can I delete only those numbers.
qqqqq112
wwwww2345
eeeee1
etc
Thank You
marino
Postby mrainey56 » Mon Jan 03, 2005 7:22 am
\d represents a digit from 0-9
$ represents the end of the line
\d$ represents a digit at the end of the line
\d+$ represents one or more consecutive digits at the end of the line
I would try:
Search: \d+$
Replace: Nothing
Unix regular expression mode
mrainey56
Postby marino » Tue Jan 04, 2005 2:17 pm
Thank You
marino
