How to search for unique lines in a file
Postby Quack » Sat Jan 08, 2005 4:25 pm
One more question i have tho... ;)
How can i let ultraedit search through the entire file, looking for duplicate lines? When it finds one it should delete the entire line, so the output will be a bunch of unique lines...
Example:
[input]
Hello
Helo
hello
[/input]
[output]
Hello
Helo
hello
[/output]
Thanks in advance :)
Quack
Re: How to search for unique lines in a file
Postby Quack » Sat Jan 08, 2005 6:52 pm
never mind, found it :)
Quack
Postby jack0fshad0ws » Mon Mar 14, 2005 4:30 pm
looking for the same thing. would you mind sharing it?:)
jack0fshad0ws
Postby mjcarman » Tue Mar 15, 2005 9:08 am
If it's desirable/acceptable for your output to be sorted, go to File->Sort->Advances Sort/Options, check Remove Duplicates, and then sort your file. If it isn't acceptable for your output to be sorted, you'll need to write a script to do it outside of UE. (A macro might be possible too.)
mjcarman
Power User
Power User
