How to add "" quotes or [] to each line
Postby kruto » Sat Jan 29, 2005 6:58 am
For example:
word1
word2 word3
word4
word 5
become:
"word1"
"word2 word3"
"word4"
"word 5"
or
[word1]
[word2 word3]
[word4]
[word 5]
Thanks !
kruto
Re: How to add "" quotes or [] to each line
Postby mrainey56 » Sat Jan 29, 2005 9:42 am
Do a search and replace with the regular expression option checked. Unix mode active (see Advanced > Configuration > Find Tab to set)
Search: ^(.+)$
Replace: "\1"
or
Replace: [\1]
mrainey56
Postby kruto » Sun Jan 30, 2005 5:54 am
Thank you, works fine :)
kruto
Postby lizard » Fri Feb 25, 2005 6:26 am
Great - glad someone has asked. I use UE for MapBasic, which doesn't have a block comment function.
I tried your solution
(Regular expressions / unix style enabled replace ^(.+)$ with '\1')
on the following text:
open file logfileP for append as #2 filetype "TEXT"
write #1, "[1997 completed]"
write #2, "[1997 completed]"
close file #2
But got: "Search string not found."
I actually need single quotes, but was just testing the principle.
What am I doing wrong, please?
Thanks, 8O Bruce
I am using version 7.10b, which doesn't have the EDIT - ADD COMMENT function.
lizard
Postby ASTTMan » Tue Mar 01, 2005 12:12 pm
You might need to check Replace All is from Top of File in the Replace dialog. I got the same result when I unchecked it.
Dave
ASTTMan
Postby psmithphil » Wed Mar 16, 2005 8:02 pm
Thank you for this post, mrainey56! With it I was able to add a semi-colon at the end of each line in a large file. You da man!
psmithphil
Postby Yendor04 » Thu May 11, 2006 3:55 pm
Hey lizard,
I was having the exact same issue you describe above. I found that by selecting the "UltraEdit style Regular Expressions" option (not the "Unix style") under Advanced -> Configuration -> Search -> Regular Expression Engine I was able to use then the Find/Replace strings specified earlier in this thread.
I would like to know how to use the Unix Style expression for this sort of inserting of text.
Yendor04
Postby deeptinker » Thu May 11, 2006 8:43 pm
Whole books have been written about regular expressions. (Try O'reilly Books.) It will take a while before you get comfortable with them.
Note that the latest versions of UE/UES have Perl style regular expressions. They build on the Unix style, but take things to a whole new level of difficulty. :)
Travis
deeptinker
Postby Yendor04 » Thu May 18, 2006 12:45 pm
Absolutely, deepthinker! Immediately following my post above I placed and order for "Mastering Regular Expressions, Second Edition" by Jeffrey Friedl and from O'reilly Publishing. Can't wait to crack that cover! Thanks!
Yendor04
