Replace the LAST found "\" in every line with "\\"
Postby c4p0ne » Sat Oct 04, 2008 1:25 pm
There are multiple "\" characters on each line, what is the proper syntax to replace the LAST "\" character in every line with "\\"?
thanks.
c4p0ne
Re: Replace the LAST found "\" in every line with "\\"
Postby pietzcker » Sat Oct 04, 2008 3:40 pm
Perl regex:
Search for \\([^\\]*)$
Replace with \\\\\1
pietzcker
Postby c4p0ne » Sun Oct 05, 2008 7:58 am
Nice thanks, but doesn't seem to be working, it's selecting the "\" and everything after it sort of like:
???? ???\25644d244vcv4d13e8b79eb65bb029c73\}:J\fake@fakeaddress.com
I need to isolate only that last "\" and replace it with "\\" (on every subsiquent line as well).
c4p0ne
Postby Mofi » Sun Oct 05, 2008 9:10 am
If you would have tried the replace, you would have seen that the replace works. Yes, the search strings also selects everything after last \ till end of line, but the replace does not modify this part. The string after last \ is tagged by ([^\\]*) and re-used in the replace string with expression \1 which means everything found by the expression in the first (...) of the search string.
Postby pietzcker » Sun Oct 05, 2008 1:51 pm
Thanks for your support, Mofi! :)
Of course, using lookahead, you could also search for
and replace all with
Then you really only select the last \ on the line. This will even be quite a bit faster than my previous solution, I expect.
pietzcker
Postby c4p0ne » Mon Oct 06, 2008 11:04 am
Thanks for your time and patience in this simple matter. It is much appreciated! :)
c4p0ne
Postby mingwu » Thu Oct 09, 2008 1:55 am
pietzcker's lookahead version is the best.
Cheers,
Ming Wu
mingwu
