add a space between bytes except for the last byte
Postby mingwu » Thu Oct 09, 2008 12:46 am
Test data:
80040400062CECCCFF00000001D73B00
Desired result:
80 04 04 00 06 2C EC CC FF 00 00 00 01 D7 3B 00
Note that there should not be a space at the end of the line.
The following simple tactics does not make me happy:
Find What: (\w{2})
Replace With: $1
(Note that there is a space after $1).
So the real challenge is: how do you implement the logic "the byte beofre new lines".
Thanks for your help in advance.
Ming Wu
mingwu
Re: add a space between bytes except for the last byte
Postby pietzcker » Thu Oct 09, 2008 1:38 am
(\w{2})(?![\r\n])
matches two characters unless they are followed by a newline character.
pietzcker
Postby jorrasdk » Thu Oct 09, 2008 1:51 am
Just add a positive lookahead to your regexp:
(\w{2})(?=\w)
ie. only match the two next word characters if succeeded by a word character
replace \1<blank>
re-edit: Oops. Simultaneous posting. But mine will also work if the last line in the file is not followed by a single newline ;-)
Postby pietzcker » Thu Oct 09, 2008 2:25 am
Unless mingwu is using an older UE version (pre-14, I think) which still has the positive lookahead bug :)
pietzcker
Postby mingwu » Sun Oct 19, 2008 5:26 am
Thanks guys.
Both version worked perfectly.
There is no bug at all, since I do not need to add a blank for a byte which is immediately followed by a newline.
mingwu
