Going to the <n>th occurrence on a line
Postby sklad2 » Wed Feb 18, 2009 12:35 pm
I have data delimited by ^
Sample:
12^eeyryr^^1122^122121^qtyewtwewt^dgheg37636^^^^s^
I would like to find the <n>th occurence of the ^
For example to find the first ^
I used \^ reg expressions and perl. I happily went to each ^
Next I tried to go to every 2nd ^ and tried \^{2}
But that did not do what I want. You regex guys are probable laughing now.
Next I tried \^[^\^]{2}
That failed too.
Also note on some "fields" they are empty like ^^ or more together.
All help is appreciated.
sklad2
Re: Going to the <n>th occurrence on a line
Postby pietzcker » Wed Feb 18, 2009 3:12 pm
This is difficult with regular expressions, especially if you only want the nth ^ to be highlighted. It wouldn't be a problem to match everything up until the nth ^, but that isn't what you need, I guess. If Perl were to support variable-length lookbehind, it would be easy to do, but sadly, that's a feature Perl doesn't have.
I see two options:
Search for all the text leading up to the nth ^ using the Perl regex ^(?:[^\^]*\^){n-1}[^\^]* - then the cursor will be placed right before the nth ^. (Of course you have to replace n-1 by an actual number)
If you want to select the nth ^, you could use the approach above in combination with a macro:
Key HOME
PerlReOn
Find RegExp "^(?:[^\^]*\^){4}[^\^]*"
Key RIGHT ARROW
Key LEFT ARROW
to select the fifth ^ in this case.
A completely different idea:
You said that these are data delimited by ^. You could use the command "Convert to fixed columns" in the Column menu and specify ^ as the separator character. This will align all the separators throughout the file, ensuring that the nth ^ is always in the same column. Perhaps that's also a possibility?
pietzcker
Postby sklad2 » Thu Feb 19, 2009 12:52 pm
Thanks for the great info!!!!!
I am very interested in all of the options you presented. :D
All of them are fantastic!!!!
sklad2
