Find In Files - slimmed down
Postby pliebrand » Thu Jul 15, 2004 9:35 am
I sometimes have a need to simply just list the files themselves instead of the actual lines my search criteria is listed on within the file. Is there currently an option to do this (I cannot find it) or something that might be considered in the future?
Thanks!
pliebrand
Re: Find In Files - slimmed down
Postby DanKirkd » Thu Jul 15, 2004 11:30 pm
I don't believe there is an option to do this today, but one workaround might be to select to list "Results to Edit Window", and then to sort those result which would gather together all the "Find" lines which list the files found.
Or if you use the Output Window, you could Copy to Clipboard, paste this into an empty edit page and sort that.
Not prefect, but it yields an answer.
Dan
DanKirkd
