Subgroups & Template-Toolkit
Re: Subgroups & Template-Toolkit
Postby Mofi » Fri Aug 26, 2011 8:37 am
Is that really impossible? What about combining both. Let's say you have the words INNERTAG, TEXTTAG, BLOCKTAG and ANEXTREMLYLONGTAG.
An expression like [ABIT][ELN][ENOX][CETX][RKT]++[EGLMNORY]++TAG matches all of them, and also many other strings. But perhaps no other strings are found in the larger context.
Postby fenway » Fri Aug 26, 2011 9:11 am
That would work if every TAG ended with "TAG" -- but they do not. They are arbitrary strings.
fenway
Postby Mofi » Fri Aug 26, 2011 11:01 am
If there is TAG or a space/tab required after optional string part does not matter. I could really help you more easily when you would provide a real data file.
Postby fenway » Fri Aug 26, 2011 11:50 am
There are over 50 such tags -- I can probably take it from here -- didn't want to be a nuisance.
fenway
Previous
