pro*c syntax highlighting
Postby petem1030 » Fri Apr 29, 2005 1:33 pm
I have a C program with SQL in it. This would be a situation where my word file contains a C_LANG section and a SQL section. Is there something I need to do to have SQL highlighted within a C program?
petem1030
Re: pro*c syntax highlighting
Postby Mofi » Thu Sep 07, 2006 12:55 pm
The multi-language syntax highlighting is only for HTML files with its languages (Javascript, PHP, ASP, CSS, ...).
You can only add the keywords for SQL to 1 or more color section of the C language definition and use Line Comment Alt = and Block Comment On Alt = and Block Comment Off Alt = definitions to specify the SQL comments also for being detected in C files.
