function list for Java
Postby xusooxusoo » Fri Sep 16, 2005 1:49 am
1)function with default access modifier.
void someMethod1(int anArg, Object anotherArg, String yetAnotherArg,
Object andStillAnother) {
2)function whose return type is an array.
private byte[] someMethod2(int anArg,Object anotherArg) {
The ultraedit would not show the function list properly,any suggestions?
XS
xusooxusoo
Re: function list for Java
Postby Mofi » Sun Sep 18, 2005 9:41 am
I don't have any Java file and I don't have experience in Java programming. You also don't have written, which Java wordfile you use. So I guess, you use that one from standard wordfile.txt. However here is the solution for your 2 examples.
Open wordfile.txt in UltraEdit directory directly or better via Advanced - Configuration - Syntax Highlighting - button Open. Then go to the function strings for Java (language 4) and add this line:
/Function String 2 = "%[ ^t]++void[ ^t]+^(*(*)^)*{$"
And modify the first function string to following:
/Function String = "%[ ^t]++[ps][a-z]+ [a-z0-9^[^]]+ ^(*(*)^)*{$"
Postby xusooxusoo » Sun Sep 18, 2005 11:07 am
Danke, Mofi. My two examples work well now with your wordfile.
Just one more issue regarding the example #1 in my original post:
If I change the 'void' into 'int' or something else, the method will not be displayed properly.any comments?
Mit freundlichem Gruss,
XS
xusooxusoo
Postby xusooxusoo » Sun Sep 18, 2005 12:18 pm
Actually the following looks better...
/Function String 2 = "%[ ^t]++[a-z]+^(*(*)^)*{$"
XS
xusooxusoo
Postby StaticGhost » Thu Oct 13, 2005 11:04 pm
Mm... but I find that none of these function strings pick up this still:
StaticGhost
Postby Mofi » Sat Oct 15, 2005 12:02 pm
StaticGhost wrote:Mm... but I find that none of these function strings pick up this still:}
Function string 2 does it, but only at following conditions:
a) The function name is written in a single line.
Working:
void someMethod1(int anArg, Object anotherArg, String yetAnotherArg, Object andStillAnother) {
Not Working:
b) No trailing spaces exist after {.
This modified function string will solve the problem with trailing spaces.
/Function String 2 = "%[ ^t]++[a-z]+^(*(*)^)*{[ ^t]++$"
Postby StaticGhost » Sun Sep 12, 2010 7:58 pm
This regex will find Java function Strings with multiple newline characters in them:
%[ ^t]++[ps][a-z]+ [a-z0-9]+ ^(*([ ^t^pa-zA-Z0-9-_,]++)^)[ ^t]++$
It now finds:
or..
                       Object anotherArg,
Much better.
Rob
StaticGhost
