Fix Indentions on Braces
Postby barkster » Mon Jul 10, 2006 8:03 pm
Will UE fix indentation errors in a php doc? I've been unable to find a way to make it fix(cleanup) an existing document. For instance:
if($color == 'blue') {
if($today == 'monday') {
//do something
else {
//do nothing
result
         //do something
    } else {
        //do nothing
barkster
Re: Fix Indentions on Braces
Postby Mofi » Tue Jul 11, 2006 3:55 pm
The ReIndent Selection feature works with the settings
/Indent Strings =
/Unindent Strings =
in your syntax highlighting wordfile for the current language (PHP for a PHP section, HTML for a HTML section, ...). So it mainly depends on you and your Indent/Unindent Strings how good or bad it works. But some code blocks (like my 'C' code with multiple } in the same line) cannot be correctly reindented.
