highlighting negative numbers?
Postby JohnJSal » Thu Oct 26, 2006 2:45 pm
Is it possible to highlight numbers preceded by a negative sign? I have numbers set to be blue, but when they are negative UE doesn't detect them.
JohnJSal
Re: highlighting negative numbers?
Postby Mofi » Fri Oct 27, 2006 2:22 pm
There are 2 solutions for it depending on the syntax/content of your file.
  1. Specify the character - as delimiter at /Delimiters = and specify - in a color group /Cx"..." which also uses the blue color like the numbers.
  2. Create a color group for negative numbers and use also the blue color for this color group. The negative numbers are defined with the substring definition. Example:
    /C8"Negative Numbers"
    ** -0 -1 -2 -3 -4 -5 -6 -7 -8 -9
Solution 2 has the advantage that words with a - in the middle like text-align are still recognized as one "word". But with solution 2 a delimiter character must exist before every negative number.
Postby JohnJSal » Fri Oct 27, 2006 2:51 pm
Thanks!
JohnJSal
