Indenting Starting on the Indent String
Postby GhotiHed » Mon May 21, 2007 11:10 pm
I'm currently using Ultra-Edit 32 v12.10a to write C++ code, and I have the following lines in my wordfile.txt file:
/Indent Strings = "{"
/Unindent Strings = "}"
This provides me with automatically indented code that looks like the following:
void blahblahdeblah()
    if (blahblahagainblah)
        asdfasdf();
    haveacow();
This is all well and good, but I've just been handed a project where I need to have the braces indented to match the enclosing code. This means the previous code should appear as follows:
        asdfasdf();
    haveacow();
I've been looking all over the place, including this forum, for information on how to do this, and the closest I can get is to use the external Artistic Style application to range over my code and redo it. I'd much rather have this done as I go.
Is there something I can set to have the indention level done starting with the indent string, rather than the line after it? Thanks.
Me
GhotiHed
Re: Indenting Starting on the Indent String
Postby pietzcker » Tue May 22, 2007 5:22 am
One way that I can think of:
If you remove the braces from the (un)indent strings list and instead use "if" "void" "while" etc. etc. as indent strings, then you'll get the indentation this way. You'll have to "outdent" manually, though.
Any other ideas?
pietzcker
Postby roland » Tue May 22, 2007 8:48 pm
I am trying, but I can't help myself... Troll alert:
Maybe that GNU style should just be banned?
roland
Postby Mofi » Wed May 23, 2007 6:25 am
A possible solution for GNU indenting style is to turn of auto-indent partly for C/C++ with empty indent and unindent strings in the syntax highlighting wordfile and write 2 macros in an automatically loaded macro file with hot keys assigned to the keys used to normally insert a { or }.
The macro can than make the indent and unindent job on pressing of key { or }. Something like that for inserting a { (with real tabs for indenting):
IfExtIs "c"
"tab{
ExitMacro
IfExtIs "cpp"
"tab{
ExitMacro
Note: tab must be a real tab character.
And something like that for inserting a } :
IfExtIs "c"
IfColNumGt 1
Key LEFT ARROW
IfCharIs 9
Delete
Key RIGHT ARROW
ExitMacro
IfExtIs "cpp"
IfColNumGt 1
Key LEFT ARROW
IfCharIs 9
Delete
Key RIGHT ARROW
ExitMacro
