ActionScript 3.0 Wordfile for UltraEdit
Postby jsexton » Fri Sep 28, 2007 9:16 pm
Hi all,
I just signed up for a forum account, so this is my first post. Since Flash CS3 has been out for a while and I couldn't find an ActionScript 3 wordfile for UltraEdit available on the net, I decided to make one.
It's an improvement on the available AS2 files as well as the syntax highlighting built into Flash itself, and includes JavaScript-style highlighted separators, root package names, and differentiation of global functions from class properties/methods, as well as the usual identifiers, statements, and operators.
The keywords are directly from Adobe's AS3 reference, with the wordfile generated by a purpose-built PHP script. I hope it helps, and feel free to use, distribute, or modify it as you see fit. If anyone wants the generator script, email me and I'll send it.
Jordan
Edit: 09/29/07
Thanks to mofi's Syntax Tools (thanks!), the wordlist is now valid and all classes, properties, etc. seem to be recognized. I've uploaded a new version (1.1) of the file. If you run into any other issues, please let me know and I'll do what I can to fix them.
actionscript 3.0 wordfile 1.1.zip
Unzip text file and append to C:\Program Files\IDM Computer Solutions\UltraEdit-32\wordfile.txt
(9.9 KiB) Downloaded 1905 times
jsexton
Re: ActionScript 3.0 Wordfile for UltraEdit
Postby Mofi » Sat Sep 29, 2007 1:47 pm
Hi jordan,
your language definition is case sensitive so a word like accept must be on a different line as word ACTIONSCRIPT. This is not the case and so the syntax highlighting will not work correct.
Use my macros SortLanguage, TestForDuplicate, TestForInvalid in the macro file SyntaxTools.mac which you can download at
The ultimate syntax highlighting tools
After you have run these 3 macros and fixed all reported errors, edit your first post and upload the new version replacing the first version.
I suggest to send the fixed version also to IDM support by email for their wordfiles download page.
Postby stroyer » Tue Nov 06, 2007 4:50 pm
jsexton wrote:I just signed up for a forum account, so this is my first post. Since Flash CS3 has been out for a while and I couldn't find an ActionScript 3 wordfile for UltraEdit available on the net, I decided to make one.
Well then I just signed up too, just to say thank you for making that AS3 wordfile. I've been using UltraEdit since CS3 came and been missing it all the time. So thanks a lot.
Chris
stroyer
Postby kevinashworth » Tue Mar 11, 2008 1:39 pm
Warning: newbie post!
Using the new wordfile (not linked to here, but the one found at Downloads - Extras) works pretty well for .mxml files (Flex development), and not just for .as files. There are small issues, however, so I'm wondering if there's a wordfile somewhere made for MXML?
For example, this code doesn't receive proper CSS syntax highlighting, though it's common in MXML files:
<mx:Style>
   Application {
      background-color:"grey";
      background-image:"bg.jpg";
</mx:Style>
How to include the syntax of CSS and AS at once? Of course the biggest chunks of my MXML files are sections that are properly highlighted within <mx:Script> tags.
kevinashworth
Postby A.Russell » Sat Nov 22, 2008 4:41 am
Thanks for this. Function strings are not recognized in the function window. The regular expression in the file I downloaded off this site has:
/Function String = "%[ ^t]++[a-zA-Z_0-9][a-zA-Z_0-9^[^]]+[ ^t*]+^([a-zA-Z_0-9]+^)[ ^t]++([^p*&:, ^t^[^]a-zA-Z_0-9./(!]++)[~;]"
I don't know regular expressions very well. Can someone tell me how to fix this so functions are recognized?
A.Russell
Postby Mofi » Sat Nov 22, 2008 10:39 am
The function string is syntactically correct. Can you post enclosed in the BB tags [code][/code] some examples of function definitions in your files. I'm not familiar with ActionScript. Post also some lines which are similar to function definition lines, but are not function definition lines.
Postby A.Russell » Sun Nov 23, 2008 8:18 am
Thanks. Here are some examples of acceptable actionscript function definitions:
       public function Score():void
                 public function AddBonusBunny(number:int = 1): void
                 public override function EventStruck(entity:Entity):void{
The only thing I can think of that might look like a function definition could be a variable declaration:
      static const BSPEED_TIME = 5000;
      private var m_PresentHit:uint = 0;
A.Russell
Postby Mofi » Mon Nov 24, 2008 8:37 am
Try following function string:
/Function String = "%*function[ ^t]+^([a-zA-Z_0-9]+^)[ ^t]++([^p*&:, ^t^[^]a-zA-Z_0-9./(!=]++)[~;]"
Explanation:
% ... start search always at beginning of a line.
* ... matches any number of occurrences of any character except newline.
function ... the line must contain this word.
[ ^t]+ ... 1 or more spaces or tabs must follow the word "function".
^([a-zA-Z_0-9]+^) ... find a string consisting only of letters a-z and A-Z, numbers 0-9 and underscores and tag that string for the function list because this is the function name.
[ ^t]++ ... 0 or more spaces or tabs can follow the function name.
(...) ... next a () pair must follow.
[^p*&:, ^t^[^]a-zA-Z_0-9./(!=]++ ... 0 or more of these charactes can be inside the () pair. ^p is a DOS line ending, ^t is a horizontal tab, ^[ and ^] are escaped [ and ] because [] has a special regular expression meaning as you can see here.
[~;] ... the character following the () pair must be a different character than a semicolon.
If that regular expression string finds too much, you have to further limit it. The variable definitions are surely no problem because of the missing word "function" and the missing () pair.
Postby MikeFoster » Mon Jan 26, 2009 2:54 pm
Mofi's function string works great. It needs to be added to the AS3 wordfile on the downloads page. Btw, thanks very much to jsexton for this wordfile - and thanks to Mofi for the function string!
MikeFoster
Postby maryv » Mon Apr 06, 2009 4:01 pm
Does anyone have a copy of the ActionScript 3.0 Wordfile mentioned earlier in this thread? I had been using it, but lost it during the upgrade to 15.00. The ActionScript wordfiles on the Extras page don't look to be ActionScript 3.0.TIA!
maryv
Postby plight » Mon Apr 27, 2009 8:33 pm
http://www.allforthecode.co.uk/forum/vi ... 18&start=0
as of 4/27/2009, this link works. I just found it after googling for 20 minutes, so i thought i'd post a link.
I haven't really verified in detail that it is 100% correct, but at a glance it looks about right.
In case the link goes dead (as the ones above seem to have) I can be reached at
plight (email provided by) gmail.com
good luck.
-PL-
plight
Postby maryv » Tue Apr 28, 2009 1:13 pm
Thanks for the link! I'll check it out. I ended up rolling my own: I use KoolMoves instead of the Adobe product. KoolMoves has a bunch of neat classes, so I've been adding them in as I go. Thanks again!
maryv
Postby sbeener » Thu Oct 15, 2009 12:47 pm
Here's an updated Classes section that includes all of AS3's classes:
/C4"Classes" STYLE_IDENTIFIER
AbstractConsumer AbstractEvent AbstractInvoker AbstractMessage AbstractOperation AbstractOperation AbstractProducer AbstractService AbstractTarget AbstractWebService
Accessibility AccessibilityImplementation AccessibilityProperties Accordion AccordionAutomationImpl AccordionHeader AccordionHeaderSkin AcknowledgeMessage ActionEffectInstance ActionScriptVersion ActivatorSkin ActivityEvent
AddChild AddChildAction AddChildActionInstance AddItemAction AddItemActionInstance AdvancedDataGrid AdvancedDataGridAutomationImpl AdvancedDataGridBase AdvancedDataGridBaseEx AdvancedDataGridBaseExAutomationImpl AdvancedDataGridBaseSelectionData AdvancedDataGridColumn AdvancedDataGridColumnGroup AdvancedDataGridDragProxy AdvancedDataGridEvent AdvancedDataGridEventReason AdvancedDataGridGroupItemRenderer AdvancedDataGridGroupItemRendererAutomationImpl AdvancedDataGridHeaderHorizontalSeparator AdvancedDataGridHeaderInfo AdvancedDataGridHeaderRenderer AdvancedDataGridHeaderShiftEvent AdvancedDataGridItemRenderer AdvancedDataGridItemRendererAutomationImpl AdvancedDataGridItemSelectEvent AdvancedDataGridListData AdvancedDataGridRendererDescription AdvancedDataGridRendererProvider AdvancedDataGridSortItemRenderer AdvancedListBase AdvancedListBaseAutomationImpl
AIREvent Alert AlertAutomationImpl AlertFormAutomationImpl AMFChannel AnimateProperty AnimatePropertyInstance AntiAliasType
Application ApplicationAutomationImpl ApplicationBackground ApplicationControlBar ApplicationDomain ApplicationTitleBarBackgroundSkin ApplicationUpdater ApplicationUpdaterUI
AreaChart AreaRenderer AreaSeries AreaSeriesAutomationImpl AreaSeriesItem AreaSeriesRenderData AreaSet ArgumentError Array ArrayCollection ArrayUtil
AsyncErrorEvent AsyncMessage AsyncRequest AsyncResponder AsyncToken Attribute AuthenticationMethod Automation AutomationDragEvent AutomationDragEventWithPositionInfo AutomationError AutomationEvent AutomationID AutomationIDPart AutomationRecordEvent AutomationReplayEvent
AverageAggregator AVM1Movie AxisBase AxisLabel AxisLabelSet AxisRenderer AxisRendererAutomationImpl
Back BarChart BarSeries BarSeriesAutomationImpl BarSeriesItem BarSeriesRenderData BarSet Base64Decoder Base64Encoder BaseListData
BevelFilter BindingUtils Bitmap BitmapAsset BitmapData BitmapDataChannel BitmapFill BitmapFilter BitmapFilterQuality BitmapFilterType
BlendMode Blur BlurFilter BlurInstance Boolean Border Bounce BoundedValue Box BoxAutomationImpl BoxDirection BoxDivider BoxItemRenderer
BreakOpportunity BrokenImageBorderSkin BrowserChangeEvent BrowserInvokeEvent BrowserManager BubbleChart BubbleSeries BubbleSeriesAutomationImpl BubbleSeriesItem BubbleSeriesRenderData BusyCursor Button ButtonAsset ButtonAutomationImpl ButtonBar ButtonBarAutomationImpl ButtonBarButtonSkin ButtonLabelPlacement ButtonSkin
ByteArray ByteArrayAsset
CalendarLayoutChangeEvent CallResponder Camera CandlestickChart CandlestickItemRenderer CandlestickSeries Canvas CanvasAutomationImpl Capabilities CapsStyle CartesianCanvasValue CartesianChart CartesianChartAutomationImpl CartesianDataCanvas CartesianTransform CategoryAxis
CFFHinting ChangeWatcher Channel ChannelError ChannelEvent ChannelFaultEvent ChannelSet ChartBase ChartBaseAutomationImpl ChartElement ChartEvent ChartItem ChartItemDragProxy ChartItemEvent ChartLabel ChartSelectionChangeEvent ChartState CheckBox CheckBoxAutomationImpl CheckBoxIcon ChildExistenceChangedEvent ChildItemPendingError
CircleItemRenderer Circular Class ClassFactory Clipboard ClipboardFormats ClipboardTransferMode CloseEvent
CollectionEvent CollectionEventKind CollectionViewError ColorCorrection ColorCorrectionSupport ColorMatrixFilter ColorPicker ColorPickerAutomationImpl ColorPickerEvent ColorPickerSkin ColorTransform ColorUtil
ColumnChart ColumnSeries ColumnSeriesAutomationImpl ColumnSeriesItem ColumnSeriesRenderData ColumnSet ComboBase ComboBaseAutomationImpl ComboBox ComboBoxArrowSkin ComboBoxAutomationImpl CommandMessage ComponentDescriptor CompositeEffect CompositeEffectInstance CompressionAlgorithm Concurrency ConfigMap ConstraintColumn ConstraintRow Consumer
Container ContainerAutomationImpl ContainerCreationPolicy ContainerLayout ContainerMovieClip ContainerMovieClipAutomationImpl ContentElement ContextMenu ContextMenuBuiltInItems ContextMenuClipboardItems ContextMenuEvent ContextMenuItem ContextualClassFactory
ControlBar ConvolutionFilter CountAggregator CreditCardValidator CreditCardValidatorCardType CrossItemRenderer
CSMSettings CSSStyleDeclaration CubeEvent Cubic CuePointEvent CuePointManager CurrencyFormatter CurrencyValidator CurrencyValidatorAlignSymbol CursorBookmark CursorError CursorManager CursorManagerPriority
DataDescription DataEvent DataGrid DataGridAutomationImpl DataGridBase DataGridColumn DataGridColumnDropIndicator DataGridColumnResizeSkin DataGridDragProxy DataGridEvent DataGridEventReason DataGridHeader DataGridHeaderBackgroundSkin DataGridHeaderBase DataGridHeaderSeparator DataGridItemRenderer DataGridItemRendererAutomationImpl DataGridListData DataGridLockedRowContentHolder DataGridSortArrow DataTip DataTransform
Date DateBase DateChooser DateChooserAutomationImpl DateChooserEvent DateChooserEventDetail DateChooserIndicator DateChooserMonthArrowSkin DateChooserYearArrowSkin DateField DateFieldAutomationImpl DateFormatter DateRangeUtilities DateTimeAxis DateValidator
DefaultDataDescriptor DefaultDragImage DefaultListEffect DefaultTileListEffect DeferredInstanceFromClass DeferredInstanceFromFunction DefinitionError DeleteObjectSample DescribeTypeCache DescribeTypeCacheRecord
DiamondItemRenderer Dictionary DigitCase DigitWidth DisplacementMapFilter DisplacementMapFilterMode DisplayObject DisplayObjectContainer Dissolve DissolveInstance DividedBox DividedBoxAutomationImpl DividerEvent
DockIcon DownloadErrorEvent DownloadProgressBar DragEvent DragManager DragManagerAutomationImpl DragSource DRMAuthenticateEvent DRMAuthenticationCompleteEvent DRMAuthenticationErrorEvent DRMContentData DRMErrorEvent DRMManager DRMManagerError DRMPlaybackTimeWindow DRMStatusEvent DRMVoucher DropdownEvent DropShadowFilter
DualStyleObject DynamicEvent
EastAsianJustifier EdgeMetrics Effect EffectEvent EffectInstance EffectManager EffectTargetFilter Elastic ElementFormat EmailValidator
EncryptedLocalStore Endian EOFError Error ErrorEvent ErrorMessage EvalError
Event EventDispatcher EventListenerRequest EventPhase EventPriority Exponential ExternalInterface
Fade FadeInstance Fault FaultEvent File FileEvent FileFilter FileListEvent FileMode FileReference FileReferenceList FileStream FileSystemComboBox FileSystemDataGrid FileSystemEnumerationMode FileSystemHistoryButton FileSystemList FileSystemSizeDisplayMode FileSystemTree
FlexBitmap FlexClient FlexContentHolder FlexContentHolderAutomationImpl FlexEvent FlexHTMLLoader FlexMouseEvent FlexMovieClip FlexNativeMenu FlexNativeMenuEvent FlexNativeWindowBoundsEvent FlexPrintJob FlexPrintJobScaleType FlexShape FlexSimpleButton FlexSprite FlexTextField FlexVersion
FocusDirection FocusEvent FocusManager FocusRequestDirection Font FontAsset FontDescription FontLookup FontMetrics FontPosture FontStyle FontType FontWeight
Form Formatter FormAutomationImpl FormHeading FormItem FormItemAutomationImpl FormItemDirection FormItemLabel FrameLabel FullScreenEvent Function
Glow GlowFilter GlowInstance GradientBase GradientBevelFilter GradientEntry GradientGlowFilter GradientType GraphicElement
Graphics GraphicsBitmapFill GraphicsEndFill GraphicsGradientFill GraphicsPath GraphicsPathCommand GraphicsPathWinding GraphicsShaderFill GraphicsSolidFill GraphicsStroke GraphicsTrianglePath GraphicsUtil
Grid GridFitType GridItem GridLines GridRow GroupElement Grouping GroupingCollection GroupingField
HaloBorder HaloColors HaloDefaults HaloFocusRect HBox HDividedBox HeaderEvent
HierarchicalCollectionView HierarchicalCollectionViewCursor HierarchicalData HistoryManager HitData HLOCChart HLOCItemRenderer HLOCSeries HLOCSeriesBase HLOCSeriesBaseAutomationImpl HLOCSeriesItem HLOCSeriesRenderData
HorizontalList HRule HScrollBar HSlider HTML HTMLHistoryItem HTMLHost HTMLLoader HTMLPDFCapability HTMLUncaughtScriptExceptionEvent HTMLWindowCreateOptions
HTTPChannel HTTPMultiService HTTPRequestMessage HTTPService HTTPService HTTPStatusEvent
IAbstractEffect IAdvancedDataGridRendererProvider IAutomationClass IAutomationClass2 IAutomationEnvironment IAutomationEventDescriptor IAutomationManager IAutomationManager2 IAutomationMethodDescriptor IAutomationMouseSimulator IAutomationObject IAutomationObjectHelper IAutomationPropertyDescriptor IAutomationTabularData IAxis IAxisRenderer
IBar IBitmapDrawable IBorder IBrowserManager IButton IChartElement IChartElement2 IChildList ICollectionView IColumn Icon IConstraintClient IConstraintLayout IContainer
ID3Info IDataInput IDataOutput IDataRenderer IDeferredInstance IDeferredInstantiationUIComponent IDropInListItemRenderer IDynamicPropertyOutput IDynamicPropertyWriter
IEffect IEffectInstance IEffectTargetHost IEventDispatcher IExternalizable IFactory IFill IFlexAsset IFlexContextMenu IFlexDisplayObject IFlexModule IFlexModuleFactory IFocusManager IFocusManagerComplexComponent IFocusManagerComponent IFocusManagerContainer IFocusManagerGroup IFontContextComponent
IGraphicsData IGraphicsFill IGraphicsPath IGraphicsStroke IGroupingCollection IHierarchicalCollectionView IHierarchicalCollectionViewCursor IHierarchicalData IHistoryManagerClient
IImageEncoder IIMESupport IInvalidating ILayoutManager ILayoutManagerClient IList IListItemRenderer IllegalOperationError ILogger ILoggingTarget
Image ImageSnapshot IME IMEConversionMode IMEEvent IMenuBarItemRenderer IMenuDataDescriptor IMenuItemRenderer IMessage IModuleInfo IMXMLObject IMXMLSupport
IndexChangedEvent InstanceCache InteractiveIcon InteractiveObject InterDragManagerEvent InterManagerRequest InterpolationMethod InvalidateRequestData InvalidCategoryError InvalidChannelError InvalidDestinationError InvalidFilterError InvalidSWFError InvokeEvent InvokeEvent InvokeEventReason
IOError IOErrorEvent IOLAPAttribute IOLAPAxisPosition IOLAPCell IOLAPCube IOLAPCustomAggregator IOLAPDimension IOLAPElement IOLAPHierarchy IOLAPLevel IOLAPMember IOLAPQuery IOLAPQueryAxis IOLAPResult IOLAPResultAxis IOLAPSchema IOLAPSet IOLAPTuple IOverride
IPreloaderDisplay IProgrammaticSkin IPropertyChangeNotifier IRawChildrenContainer IRectangularBorder IRepeater IRepeaterClient IResourceBundle IResourceManager IResponder Iris IrisInstance ISimpleStyleClient
ISOAPDecoder ISOAPEncoder IStackable IStackable2 IStateClient IStroke IStyleClient IStyleModule ISWFBridgeGroup ISWFBridgeProvider ISWFLoader ISystemManager
ItemClickEvent ItemPendingError ItemResponder IToggleButton IToolTip IToolTipManagerClient ITreeDataDescriptor ITreeDataDescriptor2
IUIComponent IUID IUITextField IURIDereferencer IValidatorListener IViewCursor IWindow IXMLDecoder IXMLEncoder IXMLSchemaInstance
JointStyle JPEGEncoder JPEGLoaderContext JustificationStyle
Kerning Keyboard KeyboardEvent KeyLocation
Label LabelAutomationImpl LayoutContainer LayoutManager Legend LegendAutomationImpl LegendData LegendItem LegendItemAutomationImpl LegendMouseEvent
LigatureLevel Linear LinearAxis LinearGradient LinearGradientStroke LineChart LineFormattedTarget LineJustification LineRenderer LineScaleMode LineSeries LineSeriesAutomationImpl LineSeriesItem LineSeriesRenderData LineSeriesSegment
LinkBar LinkBarAutomationImpl LinkButton LinkButtonSkin LinkSeparator
List ListAutomationImpl ListBase ListBaseAutomationImpl ListBaseContentHolder ListBaseContentHolderAutomationImpl ListBaseSeekPending ListBaseSelectionData ListCollectionView ListData ListDropIndicator ListEvent ListEventReason ListItemDragProxy ListItemRenderer ListItemRendererAutomationImpl ListItemSelectEvent ListRowInfo
Loader LoaderConfig LoaderContext LoaderInfo LoaderUtil LoadEvent LoadVoucherSetting LocalConnection Locale Log LogAxis LogEvent LogEventLevel LogLogger
MarshalledAutomationEvent MaskEffect MaskEffectInstance Math Matrix Matrix3D MaxAggregator MBeanAttributeInfo MBeanConstructorInfo MBeanFeatureInfo MBeanInfo MBeanOperationInfo MBeanParameterInfo
MemoryError Menu MenuAutomationImpl MenuBar MenuBarAutomationImpl MenuBarBackgroundSkin MenuBarItem MenuBarItemAutomationImpl MenuEvent MenuItemRenderer MenuItemRendererAutomationImpl MenuListData MenuShowEvent
MessageAckEvent MessageAgent MessageEvent MessageFaultEvent MessagePerformanceUtils MessageResponder MessageSerializationError MessagingError MetadataEvent
Microphone MinAggregator MiniDebugTarget Module ModuleBase ModuleEvent ModuleLoader ModuleManager MorphShape Mouse MouseCursor MouseEvent
Move MoveEvent MoveInstance MovieClip MovieClipAsset MovieClipLoaderAsset MultiTopicConsumer MultiTopicProducer
Namespace NameUtil NativeApplication NativeDragActions NativeDragEvent NativeDragManager NativeDragOptions NativeMenu NativeMenuItem NativeWindow NativeWindowBoundsEvent NativeWindowDisplayState NativeWindowDisplayStateEvent NativeWindowInitOptions NativeWindowResize NativeWindowSystemChrome NativeWindowType
NavBar NavBarAutomationImpl
NetConnection NetConnectionChannel NetStatusEvent NetStream NetStreamInfo NetStreamPlayOptions NetStreamPlayTransitions NetworkMonitor NewObjectSample NoChannelAvailableError NotificationType
Number NumberBase NumberBaseRoundType NumberFormatter NumberValidator NumericAxis NumericStepper NumericStepperAutomationImpl NumericStepperDownSkin NumericStepperEvent NumericStepperUpSkin
Object ObjectEncoding ObjectInstance ObjectName ObjectProxy ObjectUtil
OLAPAttribute OLAPAxisPosition OLAPCell OLAPCube OLAPDataGrid OLAPDataGridAutomationImpl OLAPDataGridGroupRenderer OLAPDataGridGroupRendererAutomationImpl OLAPDataGridHeaderRendererProvider OLAPDataGridItemRendererProvider OLAPDataGridRendererProvider OLAPDimension OLAPElement OLAPHierarchy OLAPLevel OLAPMeasure OLAPMember OLAPQuery OLAPQueryAxis OLAPResult OLAPResultAxis OLAPSchema OLAPSet OLAPTrace OLAPTuple
Operation Operation Operation Operation Operation Orientation3D OutputProgressEvent
Panel PanelAutomationImpl PanelSkin Parallel ParallelInstance Pause PauseInstance PerspectiveProjection PhoneFormatter PhoneNumberValidator
PieChart PieSeries PieSeriesAutomationImpl PieSeriesItem PieSeriesRenderData PixelSnapping PlotChart PlotSeries PlotSeriesAutomationImpl PlotSeriesItem PlotSeriesRenderData
PNGEncoder Point PolarChart PolarDataCanvas PolarTransform PollingChannel PopUpButton PopUpButtonAutomationImpl PopUpButtonSkin PopUpIcon PopUpManager PopUpManagerChildList PopUpMenuButton PopUpMenuIcon
Preloader PrintAdvancedDataGrid PrintDataGrid PrintJob PrintJobOptions PrintJobOrientation PrintOLAPDataGrid Producer ProgrammaticSkin
ProgressBar ProgressBarAutomationImpl ProgressBarDirection ProgressBarLabelPlacement ProgressBarMode ProgressBarSkin ProgressEvent ProgressIndeterminateSkin ProgressMaskSkin ProgressTrackSkin
PropertyChangeEvent PropertyChangeEventKind PropertyChanges Proxy
QName Quadratic QualifiedResourceManager Quartic Quintic
RadialGradient RadioButton RadioButtonAutomationImpl RadioButtonGroup RadioButtonIcon RangeError
Rectangle RectangularBorder RectangularDropShadow ReferenceError ReferencesValidationSetting
RegExp RegExpValidationResult RegExpValidator RemoteObject RemoteObject RemotingMessage
RemoveChild RemoveChildAction RemoveChildActionInstance RemoveItemAction RemoveItemActionInstance
RenderData RenderingMode Repeater RepeaterAutomationImpl Resize ResizeEvent ResizeInstance
ResourceBundle ResourceEvent ResourceManager ResourceManagerImpl Responder Responder ResultEvent RevocationCheckSettings RichTextEditor
Rotate RotateInstance RoundedRectangle RPCObjectUtil RPCStringUtil RPCUIDUtil RSLEvent
Sample SampleDataEvent SandboxMouseEvent Scene SchemaTypeRegistry Screen ScreenMouseEvent ScriptTimeoutError
ScrollArrowSkin ScrollBar ScrollBarAutomationImpl ScrollBarDirection ScrollControlBase ScrollControlBaseAutomationImpl ScrollEvent ScrollEventDetail ScrollEventDirection ScrollPolicy ScrollThumb ScrollThumbSkin ScrollTrackSkin
SecureAMFChannel SecureHTTPChannel SecureStreamingAMFChannel SecureStreamingHTTPChannel Security SecurityDomain SecurityError SecurityErrorEvent SecurityPanel SecurityUtil
Sequence SequenceInstance SerializationFilter Series SeriesAutomationImpl SeriesEffect SeriesEffectInstance SeriesInterpolate SeriesInterpolateInstance SeriesSlide SeriesSlideInstance SeriesZoom SeriesZoomInstance
ServerConfig ServiceMonitor SetEventHandler SetProperty SetPropertyAction SetPropertyActionInstance SetStyle SetStyleAction SetStyleActionInstance
SHA256 Shader ShaderData ShaderEvent ShaderFilter ShaderInput ShaderJob ShaderParameter ShaderParameterType ShaderPrecision ShadowBoxItemRenderer ShadowLineRenderer
Shape SharedObject SharedObjectFlushStatus SignatureStatus SignerTrustSettings SimpleButton SimpleXMLDecoder SimpleXMLEncoder Sine
Slider SliderAutomationImpl SliderDataTip SliderDirection SliderEvent SliderEventClickTarget SliderHighlightSkin SliderLabel SliderThumb SliderThumbSkin SliderTrackSkin
SOAPFault SOAPHeader SOAPMessage SocialSecurityValidator Socket SocketMonitor SolidColor Sort SortError SortField SortInfo
Sound SoundAsset SoundChannel SoundCodec SoundEffect SoundEffectInstance SoundLoaderContext SoundMixer SoundTransform SpaceJustifier
Spacer SpreadMethod Sprite SpriteAsset
SQLCollationType SQLColumnNameStyle SQLColumnSchema SQLConnection SQLError SQLErrorEvent SQLErrorOperation SQLEvent SQLIndexSchema SQLMode SQLResult SQLSchema SQLSchemaResult SQLStatement SQLTableSchema SQLTransactionLockType SQLTriggerSchema SQLUpdateEvent SQLViewSchema
StackedSeries StackFrame StackOverflowError Stage StageAlign StageDisplayState StageQuality StageScaleMode State StateChangeEvent StaticText StatusBar StatusBarBackgroundSkin StatusEvent StatusFileUpdateErrorEvent StatusFileUpdateEvent StatusUpdateErrorEvent StatusUpdateEvent
StreamingAMFChannel StreamingConnectionHandler StreamingHTTPChannel String StringUtil StringValidator Stroke
StyleEvent StyleManager StyleProxy StyleSheet SubscriptionInfo SumAggregator SummaryField SummaryObject SummaryRow
SwatchPanelSkin SwatchSkin SWFBridgeEvent SWFBridgeGroup SWFBridgeRequest SWFLoader SWFLoaderAutomationImpl SWFVersion SwitchSymbolFormatter
SyncEvent SyntaxError System SystemManager SystemTrayIcon
TabAlignment TabBar TabNavigator TabNavigatorAutomationImpl TabSkin TabStop
Text TextArea TextAreaAutomationImpl TextBaseline TextBlock TextColorType TextDisplayMode TextElement TextEvent TextExtent
TextField TextFieldAsset TextFieldAutomationHelper TextFieldAutoSize TextFieldType TextFormat TextFormatAlign TextInput TextInputAutomationImpl TextJustifier
TextLine TextLineCreationResult TextLineMetrics TextLineMirrorRegion TextLineValidity TextRange TextRenderer TextRotation TextSelectionEvent TextSnapshot
Tile TileBase TileBaseAutomationImpl TileBaseDirection TileDirection TileList TileListItemRenderer TileListItemRendererAutomationImpl Timer TimerEvent TitleBackground TitleBar TitleWindow
ToggleButtonBar ToggleButtonBarAutomationImpl ToolTip ToolTipAutomationImpl ToolTipBorder ToolTipEvent ToolTipManager
TraceTarget Transform Transition Tree TreeAutomationImpl TreeEvent TreeItemRenderer TreeItemRendererAutomationImpl TreeListData TriangleCulling TriangleItemRenderer
Tween TweenEffect TweenEffectInstance TweenEvent TypeError TypographicCase
UIComponent UIComponentAutomationImpl UIComponentCachePolicy UIComponentDescriptor UIDUtil UIMovieClip UIMovieClipAutomationImpl UITextField UITextFieldAutomationImpl UITextFormat
UnconstrainItemAction UnconstrainItemActionInstance UpdateEvent Updater URIError URLLoader
URLLoaderDataFormat URLMonitor URLRequest URLRequestDefaults URLRequestHeader URLRequestMethod URLStream URLUtil URLVariables Utils3D
ValidationResult ValidationResultEvent Validator VBox VDividedBox Vector Vector3D VerifyError Video VideoDisplay VideoDisplayAutomationImpl VideoError VideoEvent ViewStack ViewStackAutomationImpl
VRule VScrollBar VSlider
WebService WebService WedgeItemRenderer
Window WindowBackground WindowCloseButtonSkin WindowedApplication WindowedSystemManager WindowMaximizeButtonSkin WindowMinimizeButtonSkin WindowRestoreButtonSkin
WipeDown WipeDownInstance WipeLeft WipeLeftInstance WipeRight WipeRightInstance WipeUp WipeUpInstance WSDLBinding WSDLLoadEvent
XML XMLDocument XMLList XMLListCollection XMLLoadEvent XMLNode XMLNodeType XMLSignatureValidator XMLSocket XMLUtil
ZipCodeFormatter ZipCodeValidator ZipCodeValidatorDomainType Zoom ZoomInstance
arguments
int
uint
void
sbeener
Postby Darcey » Fri Sep 16, 2011 4:44 am
I've created a new AS3 (ActionScript 3) word file, has a lot of extras that AS3 has, doesn't quite detect functions correctly as the reg ex for this is beyond me (getters and setters are just listed as get and set) but has some 3rd party apis in there like away3d and greensock.
http://www.allforthecode.co.uk/aftc/forum/user/modules/forum/article.php?index=12&subindex=0&aid=290
Happy coding.
Darcey
