I have an extensive wordfile that I've built up over the years and don't have any problems with it specifically. My question is how to automatically select a syntax from the file when I open a specific file type.
The problem is that this particular souce code file type that I am dealing with is exported from the native developement environment as a .txt file.
Obviously I do not want to assoicate .txt to the syntax group in the wordfile. Every time I open these source files I need to go to the VIEWAS menu and select the specific file type.
Is there a way to have UltraEdit know to select the wordfile type based on the folder I open them from?
Or any other idea's on how to automatically select the wordfile type?
Appreciate any comments or suggestions.
Cheers,
Eric
