Indenting php code additionally as block
Postby vgehts » Sat Feb 14, 2009 10:10 pm
I've been playing around with the Word Wrap/Tab Settings and Reindent feature as well as the Artistic Style to try and get my php files formatted correctly, but I can't seem to find the magic setting to make it work the way I want. Here is a small sample code formatted using the Reindent feature (I set my tabs at 3):
<html>
   <head>
      <title>Some Title</title>
   </head>
   <body>
      <h1>Heading Here.</h1>
      <?php
      echo "This line was created via php code.<br/>";
      echo "So was this line.<br/>";
      But this line wasn't.
   </body>
</html>
The HTML pieces are formatted okay, but I want the lines within the <?php and ?> section to be indented one level so that it's not in the same column as the <?php and ?> markers. Like this:
      <?php
Is there a way to customize either the Reindent Selection feature or create your own Artistic Style?
Richard
vgehts
Re: Indenting php code additionally as block
Postby Mofi » Sun Feb 15, 2009 9:01 am
A ReIndent Selection test on your example worked as you want it with following settings for /L8"PHP" PHP_LANG in wordfile.uew:
/Indent Strings = "{" "?php"
/Unindent Strings = "}" "?>"
With the 2 additional strings the entire block inside <?php ... ?> is also indented.
Postby vgehts » Sun Feb 15, 2009 12:02 pm
Mofi - Thanks for the suggestion for this problem. I went ahead and made the change to the wordfile.uew file in C:\Program files\IDM Computer Solutions\UltraEdit, closed UltraEdit, reopened it and it still won't reformat the php section. Here are the two lines that I modified in the L8"PHP" section:
I also tried "<?php" instead of "?php" and that didn't help. Is there another setting that you can think of that might be controlling this?
I did notice these lines about 18 lines below where the Unindent Strings line is, but I don't know if they impact the reindenting feature:
/C2"Tags" STYLE_TAG
<? <?PHP
Richard
vgehts
Postby Mofi » Sun Feb 15, 2009 1:05 pm
You have made the modifications correct. Those indent/unindent strings produced on my computer the results you wanted. But do you have made it in the correct wordfile?
Look at Advanced - Configuration - Editor Display - Syntax Highlighting which wordfile is really used. If you upgraded from a pre v14 version of UltraEdit the wordfile in the program directory is no longer used. The wordfile now used is
%appdata%\IDMComp\UltraEdit\wordfile.uew
as displayed in the configuration dialog with correct absolute path. Also make sure that you have not currently opened a project with a project specific wordfile.
The tags in the color group are just for highlighting and don't have any influence on the indent feature.
Postby vgehts » Sun Feb 15, 2009 5:29 pm
Mofi - Herzlichen Dank! Yes, I assumed that the wordfile.uew in use was the one under C:\Program Files, it turns out that I should have been looking at the one in my Documents and Settings folder. I made the change per your original instructions and it worked. I now have it formatting the PHP sections correctly.
Nochmals, vielen Dank!
Grüße,
Richard
vgehts
