How do I remove duplicate lines?
Postby hamilton » Mon Dec 05, 2005 10:33 am
I have a problem that I hope somone can help me with :)
I have a large file, in this file I have som duplicate (an more) values for the same "primary key"- the "key" is always in the same position in the lines.
Is it possible to make (and how) a macro that delete or removes the lines that have duplicate values?
My file have more than 10.0000 lines and I would hate to do this manually :evil:
I also have to keep the file as it is, so I can't import to excel.
I have UE32 ver 11.00b.
hamilton
Re: How do I remove duplicate lines?
Postby Mofi » Mon Dec 05, 2005 11:54 am
The following macro should do the job, but only if no line exists which contains regular expression characters of UltraEdit style like +[]^%$ ... See help of UltraEdit about regular expressions in UltraEdit style. Unix style cannot be used here, because ^c is not available in a Unix style search.
Bottom
IfColNum 1
IfEof
Key END
IfColNumGt 1
Key HOME
Cut
Find RegExp "%^c^p"
Replace All ""
Key DOWN ARROW
UnixReOn
I have an idea how to do it without a regular expression search, but it is much more tricky and I now have no time to develop this macro set (it cannot be done with a single macro).
Postby hamilton » Mon Dec 05, 2005 1:33 pm
Thank you :D I dont see how the macro works, but it actually does :D this will do the job
Thanx from Norway
hamilton
Postby Bego » Mon Dec 05, 2005 3:06 pm
Hi Norvegian guy, Tag Mofi,
I added some functionality to Mofis good macro:
Make a new tab and list those double(+) lines there, cause I wanna know which lines where 2+times inside.
Then I sort them (you can kick the sort line if you want)
Check it out. :D
rds Bego
Edited my Mofi: Macro source code removed - see below for the improved version.
Bego
Postby hamilton » Mon Dec 05, 2005 6:51 pm
this macro gets better and better, I'm glad thare are some helpful people out there :)
Thank you
hamilton
Postby Mofi » Fri Dec 09, 2005 12:54 pm
Thanks Bego for the idea to collect the duplicate lines as additional info and for the information that IfFound and IfNotFound can also be used after a replace. That was new for me although I have written dozens of UltraEdit macros. Even an experienced user like I can learn from others. Thanks again.
I have modified the macro again. Now it also works for files with lines with UltraEdit style regular expression characters and it does not need a second macro as I first thought would be necessary. It now could be also converted to a macro with Unix style regular expressions instead of UltraEdit style. Only 5 simple regular expressions must be changed for Unix style.
The removing duplicate line replace command is now case-sensitive. Remove MatchCase parameter if it should ignore case.
The collection of the duplicate lines is done now with clipboard 8, which improves execution speed a lot. The duplicate lines are sorted. If someone wants this macro without collecting the duplicate line info, remove the red colored lines.
This macro is now added to my private collection of useful macros - see sticky forum topic Macro examples and reference for beginners and experts which contains a macro file with the macros DelDupInfo+ (macro below) and DelDupInfo- (macro below without the red lines).
The macro property Continue if a Find with Replace not found or Continue if search string not found must be checked for this macro.
Bottom
IfColNum 1
Find RegExp "%^([~^p]^)"
Replace All "#MOFI_RULES#^1"
Clipboard 8
Find RegExp "%#MOFI_RULES#*$"
IfNotFound
Cut
Find MatchCase "^c^p"
Replace All ""
Find Up "#MOFI_RULES#"
Key HOME
Clipboard 8
Find RegExp "%#MOFI_RULES#*^p"
CopyAppend
Key HOME
Key DOWN ARROW
Key HOME
Find RegExp "%#MOFI_RULES#"
Replace All ""
NewFile
Clipboard 8
Replace All ""
IfNotFound
"NO DUPLICATES :-)
SortAsc 1 -1 0 0 0 0 0 0
NextWindow
Edit info: Some comments added - see below!
This macro will not work for Unix files opened in Unix mode without conversion temporarily (on file load) or permanently to DOS before macro execution (^p matches CRLF!).
The macro is designed to remove duplicate lines only if a line matches another line 100%. If there are trailing spaces and the trailing spaces of 2 lines displayed identical do not match, the lines will not be removed and reported. Use the command TrimTrailingSpaces at top of the macro after the command Top, if you want to ignore trailing spaces and you can delete it.
2007-11-01: The macro has been rewritten completely because it damaged the file when there are soft-wrapped lines. The new macro works now also for a file with soft-wrapped lines. Also IfEof has been eliminated to let the macro work on Unicode files too, independent of the version of UltraEdit. IfEof works for Unicode files only since UE v13.20.
Postby Mofi » Fri Dec 09, 2005 3:24 pm
Bego: Thanks again for this interesting infos (deleted). I will take this into consideration for future macros (see improved version of the macro above).
The "#MOFI_RULES#" string is used as replacement for the regular expression character % to be able to correct handle lines like this without a regular expression (lines with different preceding and trailing spaces):
Line example
 Line example
 Line example
Another Line example
Nothing should be changed when running the macro at these 4 lines. Third line contains a trailing space, second line not! Select line 2 and 3 and you will see the difference.
PS: Hopefully nobody uses this macro and has a file with lines which already contains the "#MOFI_RULES#" string. That could lead to wrong results.
Postby Mofi » Thu Nov 01, 2007 4:12 pm
Hi sas2000,
thanks for your uedit32.ini. With your configuration I was able to reproduce the problem and find the reason why the macro failed and created a wrong output (= damaged file).
The problem was the soft-wrapping you have enabled. I normally have soft-wrapping of lines not active. I use it normally only when editing HTML files, but have it not active when running macros or scripts.
I did not know how many macro commands depend on wrapping mode on/off. Key HOME, Key END and SelectLine which I have used before for this macro to select a line with or without line ending are executed always on current displayed line which is not the entire real line if the line is currently soft-wrapped. As a result of this the previous macro worked perfect until it reached the first line which was soft-wrapped.
Additionally you have option Replace All is From Top of File active as you can see in the Replace dialog which makes the output even worse.
I have completely rewritten the macro to get correct output(s) also when soft-wrapped lines exist.
I have already deleted all of our previous posts. You can delete now the zip archives and files on your website.
As a result of turning my attention to what happens when a macro is run on soft-wrapped lines which is not designed for working in active word-wrap mode I have now to update also the macros DelDupInfo- and DelDupInfo+ in my macro collection and add many notes to my macro reference. But first I have to find out which macro commands work different depending on word-wrapp mode on/off. That will take some time.
sas2000, many thanks!
Postby sas2000 » Thu Nov 01, 2007 6:09 pm
2Mofi
It works ok now :D.
Having read your macro i think that it doesn't exist, but do you know any macro commands to switch on/off soft-wrapping & Replace All is From Top of File ?, my knowledge about macros is quite limited and this way i'll avoid problems on my own macros, i've tried :
SoftWrapOff
WrapOff
WrapWordOff
WordWrapOff
but it doesn't work, may you help me ?
Thanks. :!:
sas2000
Postby Mofi » Fri Nov 02, 2007 6:48 am
Except the active regular expression engine none of the configuration settings can be changed by a macro or script. I have already written twice to IDM support that replace option Replace All is From Top of File should be disabled internally temporarily while a macro or script is running to make the output predictable. For scripts this is the case since UE v13.20, for macros since UE v13.20a.
