Splitting text file
Splitting text file
Postby OmegaNine » Mon Sep 11, 2006 10:09 am
I am looking for a program i can use to split up text files between patterns. Like
Line 1
Line 2
Line 3
Line 4
I would want lines 1 and 2 in one file, and line 2 and 3 in another...Using "-*-" to tell it where to break up the files.
Is there A) an easy way to do this or B) a macro already writen for this?
OmegaNine
Re: Splitting text file
Postby Mofi » Mon Sep 11, 2006 10:47 am
The following macro should do the job according to your example. The macro property Continue if a Find with Replace not found must be checked for this macro.
Bottom
IfColNum 1
Find Select "-*-"
IfSel
Key HOME
IfSel
NewFile
NextWindow
Key DOWN ARROW
SelectToBottom
IfSel
NewFile
NextWindow
The macro would be much easier if the source file would look like:
Line 1
Line 2
Line 3
Line 4
Postby OmegaNine » Mon Sep 11, 2006 10:50 am
Looks like its wroking, then after getting about half way it tells me it cant creat temp file. anyway i could save those out as it comes along? (I just got this program, i know nothing)
And I can format it so that it works that way (With the -*- at the end of the text)
OmegaNine
Postby Mofi » Mon Sep 11, 2006 11:17 am
Well, the macro would be only easier with -*- at end of the text if there is never something like that:
Line 1
Line 2
Line 3
Line 4
2 -*- in sequence and no -*- at the end of the file. The macro as is works for all 3 examples. So no need to change the format of the source file.
I have never seen a problem with temp file creation. How many temp files are created during macro execution? Maybe it would be better to also automatically save and close the new files with an automatically increasing number in the filename.
Postby OmegaNine » Mon Sep 11, 2006 11:20 am
It made a little over 100 then pooped out. I think your right though, if there was a way to save and close the files as they where being created it would work flawlessly
OmegaNine
Postby Mofi » Mon Sep 11, 2006 3:21 pm
Okay! For auto saving the new files with an increasing number you must FIRST create my universal CountUp macro. The source code with description can be found at counter.
THEN modify the existing macro with this new code. You have to adapt the red highlighted filename with path. If you think you will not produce more than 999 files, you can modify all 0000 to 000.
Bottom
IfColNum 1
NewFile
"0000"
SelectAll
Clipboard 8
CloseFile NoSave
Find Select "-*-"
IfSel
Key HOME
IfSel
Key DOWN ARROW
NewFile
"F:\Temp\Test_0000.tmp
Key UP ARROW
Find "0000"
Clipboard 8
PlayMacro 1 "CountUp"
Key HOME
Key END
DeleteLine
SaveAs "^c"
CloseFile
Key DOWN ARROW
SelectToBottom
IfSel
NewFile
Key UP ARROW
Find "0000"
Clipboard 8
Key HOME
Key END
DeleteLine
SaveAs "^c"
CloseFile
Clipboard 8
