Special Case: Remove Duplicates TOTALLY, not just one
Postby UltraEditLover » Tue Nov 13, 2007 11:45 pm
I have a file that contains many words.
Suppose:
0x000021E8
0x000021EC
0x000021F0 <DUPLICATE
0x000021F4
0x00002239
0x00002238 <DUPLICATE
BOTH the duplicates need to be totally removed [not just one]
final result should be:
0x000021E8
0x000021EC
0x000021F4
0x00002239
PLEASE PLEASE help I donot know what to do. :(
In case you'r wondering what those are, these are MIPS addresses and those give me headache. :twisted:
UltraEditLover
Re: Special Case: Remove Duplicates TOTALLY, not just one
Postby Mofi » Wed Nov 14, 2007 9:05 am
Postby UltraEditLover » Wed Nov 14, 2007 8:00 pm
ULTRAEDIT THE BEST! :D
Help:
Can you post the FASTEST version below?
I deal with 669956 lines. It's taking a long time.
I donot need any logs. Also all lines are normal.
and also the MOHI_RULES text not needed but I donot know how to edit the macro.
Thanks!
UltraEditLover
Postby UltraEditLover » Wed Nov 14, 2007 10:06 pm
Request to developers:
The macro takes a long time for even 10000 [i have 669956 lines].
The sort feature is ULTRA-FAST it takes just a few seconds but leaves behind one entry, because it's very optimized unlike the macros, they need to be interpreted.
Could the developers perhaps add an option to totally remove Duplicates option into the Advanced Sort options, Plz? :lol:
UltraEditLover
Postby pietzcker » Thu Nov 15, 2007 7:13 am
If you have UE V12 or higher and use Perl Regular Expressions and check "Regular Expressions" in the "Replace" dialog, then you can use the following search text:
^(.*)\r\n\1\r\n$
and "replace all" with nothing.
This should be a lot faster than macros.
This only works for duplicates, not triplicates or more.
HTH,
Tim
pietzcker
Postby scallanh » Thu Nov 15, 2007 5:45 pm
That's not quite right. This should work (adjust the line endings if it's not a DOS/Windows file, and "replace all" with nothing):
^(.*\r\n)\1+
scallanh
Postby pietzcker » Thu Nov 15, 2007 9:19 pm
You're right, your regex works for triplicates, and mine doesn't. Yours is also much more elegant. Thanks. I'll edit the offending post...
Tim
pietzcker
