'switchUE.vbs
'Switch between 2 (TWO!!!) UltraEdit installations
'PREREQUISITES:
'- Active folder is called like ...\UltraEdit
'- A second folders has to be named like ...\UltraEdit11 (with a SUFFIX as difference)
'- Make sure there are no UEdit* files in your Windows directory !
'Use the star (*) to look for configs YOU have to do :-)
Option Explicit
Dim shl
Dim exename
Dim folderNewVersion 'check what is currently active + Plausicheck
DIM folderOldVersion 'check what is currently active + Plausicheck
Dim folderRunVersion
Dim folderAktVersion
Dim folderPasVersion
Dim args
Dim fso
DIM AKTVERSION 'aktive Version
DIM PASVERSION 'passive Version
DIM OLDVERSION
DIM NEWVERSION
DIM SLASH
DIM cntFolders
dim answer
OLDVERSION = "11" '*
NEWVERSION = "12" '*
folderRunVersion = "C:\Progra~1\Ultraedit" '*
folderNewVersion = folderRunVersion & NEWVERSION
folderOldVersion = folderRunVersion & OLDVERSION
exename = "uedit32.exe"
SLASH = "\"
cntFolders = 0
'*** No more modification needed from here on ... ***
Set fso = CreateObject("Scripting.FileSystemObject")
cntFolders = abs(fso.FolderExists(folderRunVersion)) + _
abs(fso.FolderExists(folderNewVersion)) + _
abs(fso.FolderExists(folderOldVersion))
'first, test the installation with its current configuration
if cntFolders <> 2 then
MeldungRaus ("Error. There are no 2 Ultraedit-Installations found. Found " & cntFolders)
'else
' MeldungRaus ("Looks good. Found " & cntFolders)
end if
if fso.FolderExists(folderNewVersion) then
AKTVERSION = OLDVERSION
PASVERSION = NEWVERSION
else
AKTVERSION = NEWVERSION
PASVERSION = OLDVERSION
end if
folderAktVersion = folderRunVersion & AKTVERSION
folderPasVersion = folderRunVersion & PASVERSION
answer = MsgBox("Active UE is version " & AKTVERSION & "." & vbcrlf & _
"Should version " & PASVERSION & " be activated ?" & vbcrlf & vbcrlf & _
"YES=activate and start" & vbcrlf & _
"NO =just activate, no UE start" & vbcrlf & _
"Cancel = do nothing" & vbcrlf _
, vbQuestion+vbYesNoCancel, "Switch active UE-Version. CLOSE RUNNING UE's NOW !!!")
if answer = vbcancel then
wscript.quit
end if
'activate
'msgbox folderRunVersion & "-->" & folderAktVersion & vbcrlf & _
' folderPasVersion & "-->" & folderRunVersion
fso.MoveFolder folderRunVersion, folderAktVersion
fso.MoveFolder folderPasVersion, folderRunVersion
if answer = vbyes then
'Start UE
Set shl = WScript.CreateObject("WScript.Shell")
shl.Run folderRunVersion & SLASH & exename,1 ,FALSE
end if
wscript.quit
Sub MeldungRaus (strMeld)
wscript.echo strMeld
wscript.quit 1
End Sub
