Move line up and down
Postby Cye3s » Wed May 02, 2007 8:03 am
Can UE add this two features?
Move Up Current Line
Move Down Current Line
Many free text editor have this features.
Cye3s
Re: Move line up and down
Postby Mofi » Wed May 02, 2007 9:44 am
Yes, with 2 JavaScripts or 2 macros assigned to hotkeys for fast execution you can move current line up or down. Here is the macro for current line down:
SelectLine
Cut
Key DOWN ARROW
Key UP ARROW
The cursor is at start of the moved line after execution.
Postby Cye3s » Wed May 02, 2007 12:28 pm
I write 2 macros like this, but it failed at the last line without push the "Enter" key.
Like this(The second line):
Line1 1111
Line2 2222
Line3 3333(No "Enter" here)
Sorry for my poor English :-)
Cye3s
Postby Mofi » Wed May 02, 2007 2:08 pm
I really don't like text files where the last line has no line termination.
Here is the macro for Line Down which handles this situation also correct:
Key END
IfEof
SelectLine
Cut
Key DOWN ARROW
Key END
IfEof
Key HOME
IfColNumGt 1
Key HOME
Key UP ARROW
And here is the macro for Line Up:
Key END
IfEof
Key UP ARROW
SelectLine
Cut
Key UP ARROW
Key UP ARROW
Note: These macros will not work for Unicode or UTF-8 files because of a bug with IfEof in currently latest release v13.00a+2 of UE (and any previous version).
2007-11-02: The IfEof bug with Unicode files was fixed in UE v13.20.
2010-12-31: Inserted command Key UP ARROW in the macro for moving line up to set the cursor to start of just moved line to be able to use the macro immediately again.
Postby Cye3s » Thu May 03, 2007 12:17 am
Thank you :-)
Cye3s
Postby Cye3s » Wed Jun 13, 2007 7:20 am
Another problem : Undo to the original state must press "CTRL + Z" many times. Very inconvenient.
Add this feature please :-)
Edit: Move current line up and down is supported by UltraEdit since v14.00.
Cye3s
